Chris HB Posted Tuesday at 18:39 Posted Tuesday at 18:39 Hi, I’m hoping to re-use the existing old T&G floorboards from my Small Mission Hall on top of new insulated RC floor slab. this is assuming I’ll be able to get most up in a reasonable condition. I don’t mind a bit of raggedy! 🤣 Wondering what then are the best options for fixing them down? Floor area is about 34m sq Have them laid as a floating floor? Use some form of self contact adhesive to fix direct to the concrete? Fix battens down first to the concrete and then fix the floorboards to the battens? Any other options/suggestions or recommendations?
Bonner Posted Wednesday at 09:10 Posted Wednesday at 09:10 I would be inclined towards battens, have you installed underfloor heating, that might make a difference? 1
Mr Punter Posted Wednesday at 11:02 Posted Wednesday at 11:02 I doubt glue down will be good, so battens fixed to the floor with concrete screws. You could run cables in steel conduit if you need to. Floating floor could also work but you would need perimeter expansion allowance and tongue securely glued to groove. 1
Chris HB Posted Wednesday at 12:24 Author Posted Wednesday at 12:24 3 hours ago, Bonner said: I would be inclined towards battens, have you installed underfloor heating, that might make a difference? No, not going the underfloor heating route
Chris HB Posted Wednesday at 12:26 Author Posted Wednesday at 12:26 1 hour ago, Mr Punter said: I doubt glue down will be good, so battens fixed to the floor with concrete screws. You could run cables in steel conduit if you need to. Floating floor could also work but you would need perimeter expansion allowance and tongue securely glued to groove. Like a 5-10mm gap width wise? It’s under 4.500mm wide overall once studs and insulation are fitted.
Mr Punter Posted Wednesday at 18:53 Posted Wednesday at 18:53 6 hours ago, Chris HB said: Like a 5-10mm gap width wise? It’s under 4.500mm wide overall once studs and insulation are fitted. It is a bit tricky as traditionally t&g floorboards were nailed down and there was expansion available between each board, which could be 5mm. If they are glued together the 5mm no longer applies and has to be multiplied by the number of boards which would be too much over 4.5m. Maybe the battens min 45mm will be better. 1
