Adsibob Posted November 2, 2025 Posted November 2, 2025 We have some Shelly Motion sensors rigged up (wirelessly) to a Shelly Plus 1PM that’s connected to a pump. Although it was a pain to set up and configure, once I got it working it has worked flawlessly for the past 3.5 years… except for one thing: in the last 18 months I’ve noticed that the battery life has gotten worse. They used to last a year before needing to be recharged. But over the last 18 months the life post charge has got shorter and shorter. Looking at my logs I see that it reported low battery three times in the last 9 months, so I’m getting an average of 3 months per charge. Wondering if anyone else has experienced this. Looking at the webstore it appears they’ve discontinued the particular product I’ve got, which was simply called “Shelly Motion”. Maybe this is why.
Temp Posted November 3, 2025 Posted November 3, 2025 (edited) Seems others have had similar issues but I couldn't find a recommended solution. Some say firmware, some say WiFi range etc. https://community.home-assistant.io/t/shelly-motion-sensor-battery-draining-fast/568442 https://www.facebook.com/groups/ShellyIoTCommunitySupport/posts/7363638563735444/ https://www.facebook.com/groups/ShellyIoTCommunitySupport/posts/5593851320714186/ I wondered if something was trying to talk to it too frequently increasing power consumption due to increased WiFi traffic? Found this on that last link above.. Edited November 3, 2025 by Temp
Adsibob Posted November 3, 2025 Author Posted November 3, 2025 Thanks @Temp, as the last comment on the thread you found says, I’m in the same boat: I have three Shelly motions and yet only one has this problem. I will try rebooting it, as I’m not sure how to communicate with it via the browser. Do they mean just a web browser?
Temp Posted November 3, 2025 Posted November 3, 2025 42 minutes ago, Adsibob said: Do they mean just a web browser? Yes it appears to suggest you just browse to the URL.. <motion_IP>/psovrd (replace <motion_IP> with the IP address of the device) then to <motion_IP>/cancel_psovrd. I don't know if it will actually return a web page each time.
