Our stove has been in the house 10 years. Decent stove, charnwood country 6. Athough its always had a smell from it which has been quite fustrating. We only burn in it even though its multi fuel, should i remlve the grate?
The fire cement is all broken so ive pulled it out to clean and going to refit it with fresh cement.
Just want to check that this setup is correct. The flue goes inside the stove collar and then theres another cone shaped adaptor that fits inside the flue then straight into the chimney void
looks logical, the cone chimney adapter seals the flue and directs any falling soot or detritus into the fire chamber.  Regards smell, I'd probably make sure you have a flue temp sensor, and make sure there's a carbon monoxide sensor in the room.  My stove smells a bit if I'm burning too hot for too long.
Got it back in, working fine but still a very noticeable smell
I usually burn softwood logs, very dry.
Would hardwood make a difference to the smell, doubt it myself
