saveasteading Posted October 27, 2025 Posted October 27, 2025 There was a leak at the rubber doughnut thing, so I've fitted a new one, and new bolt connectors. But it's as bad. I have either over or under tightened, I'm thinking. So tomorrow I will try again. Daylight will help. Should I add plumbers gunk as a matter of course? The instructions say nothing. First though I intend to fill the cistern, but not flush, to check it's not at the fixings.
Nickfromwales Posted October 27, 2025 Posted October 27, 2025 3 hours ago, saveasteading said: There was a leak at the rubber doughnut thing, so I've fitted a new one, and new bolt connectors. But it's as bad. I have either over or under tightened, I'm thinking. So tomorrow I will try again. Daylight will help. Should I add plumbers gunk as a matter of course? The instructions say nothing. First though I intend to fill the cistern, but not flush, to check it's not at the fixings. Conclusion: You did a shit job lol. The ‘leak’ is seldom from the doughnut washer, and more often from the bolts. When did this leak? Continuously, or when flushing? If it’s a daylight issue, then please do consider fitting a light in the bathroom. Your family will thank you. 1
Big Jimbo Posted October 28, 2025 Posted October 28, 2025 (edited) 9 hours ago, Nickfromwales said: If it’s a daylight issue, then please do consider fitting a light in the bathroom. Your family will thank you. Perhaps it's the nightclub vibe. Edited October 28, 2025 by Big Jimbo 1
saveasteading Posted October 28, 2025 Author Posted October 28, 2025 Full report later. I'm pretty sure it's only when flushing. Spellchecker changed that to blushing. It was late so I just emptied the cistern, mopped the floor, opened a can and hoped for a plumber's secret to be revealed. Eg whatever you do don't under/over tighten. There are no instructions and the bottom nuts are plastic, so I assumed that it should be finger tight only. The new gasket is a foam rubber thing so could be squashed a lot more, for better or worse. 1
saveasteading Posted October 28, 2025 Author Posted October 28, 2025 Thanks I took all your expert advice to do it again properly. Everything tighter and a dab of fernox to make sure. In my defence... Knowing more about steel buildings than plumbing... if there is a leak in a steel clad roof the likeliest problem is a screw with a complete bodge covered in mastic. Second is a screw overtightened, breaking the seal from the washer.
