Mr Blobby Posted October 24, 2025 Posted October 24, 2025 (edited) So, after frustrating delays all summer, the only option I now have for rendering this year is the last week of November. Which in Northern Ireland means its cold, dark and wet. Do I reject the builders optimism and assurances and hold off until April/May? Or chance it with the weather? This is so damn annoying. Block house. KRend HP12 base coat + K1 silicone. No gutters up so walls are usually nice and wet. Edited October 24, 2025 by Mr Blobby
Conor Posted October 24, 2025 Posted October 24, 2025 No, just get it done. Ours was done in December. we only had a small area wash off. The silicone renders cure quickly, even in the cold. 1
nod Posted October 24, 2025 Posted October 24, 2025 Yep We render right through the winter The render will stand cold temperatures But frost is the worst enemy It needs to be 2 above and rising through the day Ideally scraped the same day Better to have your gutters on Even in summer 1
Mr Blobby Posted October 24, 2025 Author Posted October 24, 2025 (edited) 17 minutes ago, nod said: Better to have your gutters on Even in summer I agree. I wish gutters had been installed, even temporarily, a year ago. Walls are green at the valleys so I recently put temporary guttering up at the valleys. Our builder doesnt seem to care about this. Down to me to clean the green off before the rendering is done. Edited October 24, 2025 by Mr Blobby
nod Posted October 24, 2025 Posted October 24, 2025 2 hours ago, Mr Blobby said: I agree. I wish gutters had been installed, even temporarily, a year ago. Walls are green at the valleys so I recently put temporary guttering up at the valleys. Our builder doesnt seem to care about this. Down to me to clean the green off before the rendering is done. If it doesn’t cause the render to wag off you will be left with a massive clean up job after the rendering is finished 1
Mr Blobby Posted October 26, 2025 Author Posted October 26, 2025 On 24/10/2025 at 21:16, nod said: If it doesn’t cause the render to wag off you will be left with a massive clean up job after the rendering is finished I have been assuming for the last year that the gutters are not installed (brackets are in place) because the render needs to go behind the gutter at the top and gutters would cause an obstruction. And so I have never questioned it. I will ask the builder tomorrow why the gutters are not installed tomorrow and suggest that gutters need to be in place to protect wet render. Are gutters normally installed before rendering?
dpmiller Posted October 26, 2025 Posted October 26, 2025 will you have a fascia to fit or will will the render be stepped over the top board?
nod Posted October 26, 2025 Posted October 26, 2025 Yes they are normally installed and temporary Down pipes also But if the gutters and brackets are fitted directly to the render You will need to pick a dry couple of days 1
