How best do I insulate above this boiler hatch. There's 270mm (100+170) of roll stuff in the main roof then 250m of stacked Rockwool batts above the boiler...except for above the hatch.
IMG_20251011_181250995_HDR
IMG_20251011_181300262
IMG_20251011_181330676
IMG_20251011_181321139
44 minutes ago, Conor said:
I filled a bin bag with wool and wedged it into the hatch space. Pull it out when you need access.
I'll was just a bit worried the bin bag material is rather flammable.
Make an insulated secondary panel, which you lift up into the attic, as putting anything on that hatch will prevent access.
Use PIR wrapped in gaffa tape for the secondary panel.
