Big Jimbo Posted October 6, 2025 Posted October 6, 2025 Which do you think might cost more. 1. house built of brick 2. house built of blocks. With say the top half clad in a cement board, and the bottom half rendered. I'm going to cost up both ways, but my thoughts before i start..... Scaffold up. Brick built. Job done. Or Scaffold up. Block built. scaffold has to stay up for cladding top half, and rendering of bottom half. Although i would pay more for labour with brick built, and the additional cost of bricks over blocks. My guess will be that brick built will be cheaper....
nod Posted October 7, 2025 Posted October 7, 2025 I render or part render over a hundred new site houses each year and the builders recon they work out about the same 1
Mr Punter Posted October 7, 2025 Posted October 7, 2025 The cement board cladding, like Hardie, Cembrit, Marley etc. is expensive. Probably over £50/m2 with battens, trims and fixings. Render on blockwork is much cheaper, even if it is posh stuff. 1
