SWA cable for Graf One 2 Clean?
Maybe I am looking in the wrong place, but I cannot find any mention as to how many watts the Graf compressor and control panel use.  I suspect it's not much and I just need a 50m roll of 1.5mm 3 core SWA?
1 hour ago, Alan Ambrose said:
Reckon, 1.5mm will take >4kW, box is probably <100W.
Yes.  I did assume that as it markets itself on very low power consumption, it had to be 1.5mm2
The installation manual states that it must be on its own 16A MCB.
However, I have installed these on a 13a fusespur with the largest 120 air compressor with no issue. If you have a gravity system the power draw is tiny, however if you have a pumped outlet, I would install on a 2.5mm 16a dedicated circuit as per the manual.
