sgt_woulds Posted September 30, 2025 Posted September 30, 2025 I've tried asking this in the flat roof section, but I guess no one goes there!   In other parts of the world, you can buy white EPDM to keep the summer temperatures down, but not in Blighty, so I had to use bog-standard black.  I've done everything I can to mitigate the summer heat on our 55m2 dormer flat roof (ventilated deck, woodfibre insulation, careful airtightness detailing), and whilst these have helped over summer, it could be better.  Does anyone have any recommendations for a reflective paint that works well on EPDM?    Â
SteamyTea Posted September 30, 2025 Posted September 30, 2025 Technology & Physics  Light-filtering paint cools your home when exposed to hot sun 9 October 2017  By Sandrine Ceurstemont  Ordinary red roof tiles against a white sky A cool feature if painted right  polarica/Getty  The sun itself could soon become a low-cost air conditioner. A high-tech paint that actually cools when exposed to sunlight can provide a better way to chill buildings – and perhaps even solve the long-standing problem of cooling things in space.  In hot weather, electricity consumption soars as people turn on the air conditioning, pushing the grid to its limits and raising energy bills. Now Yaron Shenhav and his colleagues from SolCold, a firm based in Herzliya, Israel, have come up with an alternative that doesn’t require electricity. “It’s like putting a layer of ice on your rooftop which is thicker when there is more sun,” he says.  The technology is based on the counterintuitive principle of laser cooling, in which hitting specially designed materials with a laser can cool them by up to 150°C. It works because molecules in these materials absorb photons whose light is of one frequency while spontaneously re-emitting higher-frequency photons, which also carry more energy. Since energy is lost, the temperature of the material is reduced in the process.  Mounting lasers on your roof wouldn’t be very practical, though, so Shenhav wanted to see if he could tweak the technique to make it work with sunlight instead. “Heat from a building could be absorbed and re-emitted as light,” he says. “As long as the sun is shining on it, it would be continuously cooled.”  The problem is that the sun’s spectrum is much broader than that of laser light – a focused beam with a narrow range of frequencies. So the team had to create a material that could do the same trick using several frequencies of scattered light. They came up with a paint made up of two layers: an outer layer that filters out some of the sun’s rays and an inner one that does the heat-to-light conversion, cooling itself below the ambient temperature.  So far, the material has been successfully tested in the lab, where the researchers have found that the effect is more pronounced on metal roofs than on concrete, and works best over rooms with low ceilings. Simulations show that a room on the top floor will feel up to 10°C cooler than with the paint applied if applied to a roof of a house than without the coating. The team will conduct pilot tests on buildings within two years.  People already use white cooling paints to scatter and reduce the amount of heat buildings absorb. However, they can’t actively reduce the temperature in the building, whereas SolCold’s paint can, says Eran Zahavy at the Israel Institute of Biological Research, who was not involved in the research.  Cut the air conditioning The new paint isn’t cheap, costing about $300 to coat 100 square metres. Shenhav and his team think the early adopters will be large commercial buildings like shopping malls and stadiums. There, the coating could lower energy consumption by up to 60 per cent, massively reducing bills and carbon emissions.  It could have other knock-on environmental benefits as well. The continuous use of air conditioning in already hot areas like Phoenix, Arizona, creates urban heat islands which have been linked to steadily rising temperatures in such cities. With the new paint, “buildings would be able to install much smaller air-conditioning units,” says Shenav.  The paint’s use isn’t limited to this planet: it could solve the significant challenge of how to cool objects in space. That might seem counterintuitive given the frigid temperatures there, but the problem is that there is no air to carry heat away from an object. Currently, the ISS uses reflective fabric to ward off radiation from the sun, and internal heat exchangers to get rid of excess heat produced by equipment. “With our technology, heat is transferred through light,” says Shenhav. “Space applications are a big market for us.”  The team will be presenting their work later this month at the Hello Tomorrow technology summit in Paris.
saveasteading Posted September 30, 2025 Posted September 30, 2025 Roof tiles are good absorbers of heat, then releasing it overnight, esp as air gets in and around them. Â In my experience a tiled but uninsulated roof lets in less heat than a modestly insulated ( previous regulations) metal roof. A galvanised or light colored metal roof reflects a large proportion of the sun's heat. Â I'm sure it's still possible to get reflective flat roof coating, whether white or silvered. I used to use a bitumen paint product with aluminium filings in it. This was to coat inside galvanised gutters. The aluminium rose to the top leaving it as shiny as before. Perhaps this could be applied to a flat roof. I've no idea where to find this now.
torre Posted September 30, 2025 Posted September 30, 2025 Interesting topic, something we might need to look at ourselves in future. it looks like Covalba may have a suitable product, I'd also thought about white pebbles but I'm not sure I'd like the look. Â Another idea might be pale tiles on pedestals (I mentioned this in another thread) which also adds an air gap between the reflective tiles and the roof. Wind uplift might be a worry though
saveasteading Posted September 30, 2025 Posted September 30, 2025 1 hour ago, torre said: Wind uplift might be a worry though Not if the tiles are loose laid. They might displace in a gale but that would avoid the grid being lifted. White grit might be better than pebbles and could be stuck down. Roofing felt used to be protected by grit. It was there to reduce abrasion but also caught the heat.
saveasteading Posted September 30, 2025 Posted September 30, 2025 I've googled solar reflective paint. It appears to be a standard product, and easy to apply.
sgt_woulds Posted September 30, 2025 Author Posted September 30, 2025 Unfortunately, the Covalba covatherm paint doesn't appear to be available in the UK.  My roof is already a ventilated warm roof design (raised deck / ventilated airspace / woodfibre insulation / SIPs roof structure), so no benefit in adding an additional ventilated layer above the EPDM deck, even if it doesn't get blown away 🙂    Â
sgt_woulds Posted September 30, 2025 Author Posted September 30, 2025 4 minutes ago, saveasteading said: I've googled solar reflective paint. It appears to be a standard product, and easy to apply.  I'm looking for recommendations where the product is designed for EPDM, and any real life feedback.  I've used reflective paint on felt, but never on EPDM. The results were mixed, and most started cracking within 2 years and needed re-applying.   I suppose I could glue a load of CDs to the roof! 🙂 Â
SteamyTea Posted September 30, 2025 Posted September 30, 2025 14 minutes ago, sgt_woulds said: I suppose I could glue a load of CDs to the roof How about some PV, that will soak up a greater percentage of energy the more sunlight hits the roof. It also produces electricity. Â You could lay them flat (or a very shallow angle). 1
sgt_woulds Posted September 30, 2025 Author Posted September 30, 2025 I'm an ex-solar installer - already got panels on the front roof and would happily add more 🙂  Unfortunately, there are structural issues with adding more panels to the dormer roof, even if I could afford it. Which I can't...    Â
