Nickfromwales Posted November 9, 2025 Author Posted November 9, 2025 We’ve been using Passive Purple again, on the current (now pretty much an EnerPHit level refurbishment of a masonry dwelling) and it’s good stuff. When you’ve lots of nooks & crannies to seal / tape, and a mixture of substrates, then this just seems to be a great product. This plus a boatload of FM330 foam, and some meticulous membrane and taping, should get us in good stead for the arrival (soon) of AeroBarrier to put the cherry on the cake. Anyone wanting to go airtight and are in need of a paintable solution, or one you can spray through a HVLP gun also, then chat to Adam and the team at Intelligent Membranes, and they’ll give you support and advice a-plenty. Great people who have bent over to help out with technical (and practical!) advice; both on and off site. 👍👌 They’ve expanded services and products a lot so worth checking out if they have anything to make life simpler / the job (and end results) better
Alan Ambrose Posted December 2, 2025 Posted December 2, 2025 A couple of questions: + anyone used ROTHOBLAAS air tight tapes instead of Pro Clima? e.g. https://insulationmerchant.com/products/rothoblaas-seal-band-60-airtightness-tape . I know their screws get proper SE reverence, so maybe their tape is pretty good also? and... + there's a bit of a fuss re CT1 being maybe less than magic: https://youtu.be/bwvE9FqjfQA - anyone have any views?
Onoff Posted December 2, 2025 Posted December 2, 2025 I've used Illbrück expanding tape instead of Compriband. Seems good.
