September 8, 20251 yr Hi Can anyone advise what thickness of glass is needed for an external Glass Balcony Balustrade in Scotland also the tube dimensions. I am going to order the attached but just wanted to make sure it met building control standards before I do. thanks Pre-Assembled Post_Glass Clamp_Linear_Tech LC-140262.pdf
September 8, 20251 yr Not sure if the regs in Scotland are different....but in England 'Balconette' suppilied my Glass Balcony Balustrade as 10mm toughened glass which passed the Building control standard ok and their video linked below also says their frameless systems use 21.5mm laminated and toughened glass:- https://www.balconette.co.uk/
September 8, 20251 yr 2 hours ago, GrantMcscott said: Hi Can anyone advise what thickness of glass is needed for an external Glass Balcony Balustrade in Scotland also the tube dimensions. I am going to order the attached but just wanted to make sure it met building control standards before I do. thanks Pre-Assembled Post_Glass Clamp_Linear_Tech LC-140262.pdf 155.49 kB · 4 downloads All depends on location and wind loading, size of glass panel and height of drop. Really need structural engineer to specify design requirements and go from there. Article here to read https://www.iqglassuk.com/technical-advice/regulations-and-best-practice-for-glass-balustrades/s88644/ Edited September 8, 20251 yr by JohnMo
