Rosslyn Posted August 13, 2025 Posted August 13, 2025 Thames Water point you towards their approved contractor for new spur connection I need (in bridleway). But there also looks to be an option to have another contractor carry out the work subject to their approval and inspection. A nearby property spent £14k for 5m connection so hoping to avoid! https://www.thameswater.co.uk/help/home-improvements/how-to-connect-to-a-sewer Has anyone gone through this process successfully?
Kelvin Posted August 13, 2025 Posted August 13, 2025 No but £14,000 for a 5m section of pipe and connection. Sheesh! If that’s typical and you have the room then a treatment plant and drainage field (or somewhere else you’re allowed to drain to) must be surely tempting. No wastewater charge either. Our treatment plant and drainage field cost just under £5k installed.
Rosslyn Posted August 14, 2025 Author Posted August 14, 2025 A septic tank would be tempting as that is what's there now. I'm on one at my present house and the problem is that the water table gets very high over a wet winter and I think would be problematic.
crooksey Posted August 14, 2025 Posted August 14, 2025 Get a pumped outlet, have a very shallow drainage field, it will be fine (as long as the water table is not stupidly high). Or if there is a ditch on/bordering the property, discharge to this. Septic tanks are known for not being horrendous in high water table areas and rely on gravity, so the drainage fields are often set far to low.
Temp Posted August 14, 2025 Posted August 14, 2025 On 13/08/2025 at 08:31, Rosslyn said: Thames Water point you towards their approved contractor for new spur connection I need (in bridleway). But there also looks to be an option to have another contractor carry out the work subject to their approval and inspection. A nearby property spent £14k for 5m connection so hoping to avoid! https://www.thameswater.co.uk/help/home-improvements/how-to-connect-to-a-sewer Has anyone gone through this process successfully? Lot depends on the land it has to cross. Is the connection in a country road or A road etc
Rosslyn Posted August 15, 2025 Author Posted August 15, 2025 18 hours ago, Temp said: Lot depends on the land it has to cross. Is the connection in a country road or A road etc It's just a bridleway with residents vehicle access (3 houses!)
Rosslyn Posted August 15, 2025 Author Posted August 15, 2025 21 hours ago, crooksey said: Get a pumped outlet, have a very shallow drainage field, it will be fine (as long as the water table is not stupidly high). Or if there is a ditch on/bordering the property, discharge to this. Septic tanks are known for not being horrendous in high water table areas and rely on gravity, so the drainage fields are often set far to low. Yes it does get too high some Winters. Drainage into any ditch is a no no and can't even do so for rainwater. The peercolation test already excludes regular soakaway and suggested use of Swales.
