puntloos Posted August 4, 2025 Posted August 4, 2025 One of our passivhaus rooms is unexpectedly getting warmer than we hoped, and as such we will have to add one more fan coil unit. The challenge is that the aircon team isn't really well versed in passivhaus, so I'm trying to find a guide on how to drill a hole into a passivhaus wall and then sealing up the gaps left by having a hole with a pipe. To my understanding so far I have: - Pro Clima Tescon Sprimer Spray Primer - Orcon F - Passive Purple Airtight Liquid Vapour Control Membrane Spray - Contega Solido SL tape or (and?) Tescon No 1 tape And steps: 1/ Drill, clean drill site. 2/ Fix aircon pipe in place 3/ Fill large gaps with filler (orcon F?) 4/ Apply Primer 5/ Purple membrane spray (2 layers) 6/ Cure for 48 hours 7/ Tape with the Shingling method 8/ Rainscreen cladding somehow? To protect the tape? 9/ Perhaps finish for visuals? Is the above correct? I'm especially fuzzy what it looks like when an outdoor wall (with its render?) has a bunch of tape stuck to it? Or is there some way to eg apply render over all this?
Redbeard Posted August 11, 2025 Posted August 11, 2025 Hi. You say On 04/08/2025 at 17:37, puntloos said: (with its render?) Is the wall in question rendered, or was that added as an extra variable? I would do 1 and 2 as you suggest, and add 2(a) remove render for approx 100mm diameter. Fill BIG gaps (should there be any, given a 'clean' hole?) with mortar. Allow to dry Prime area and pipe with air-tightness tape primer. Leave to dry tacky Apply one of the 'fluffy' a/t tapes designed to be plastered/rendered onto. (Pavafix Win or (?) Pro Clima Contega (?may have changed its name?). Lap the tape onto the pipe just a tiny bit less than the depth of the render. Apply render. Alternatively use an EPDM grommet but I have not yet refined the thought-process for ensuring that the EPDM square stays stuck to the wall. You'd still need 'fluff tape' over the EPDM anyway, so maybe this is a non-option. Your mention of render is not repeated in your 'steps', so I may have got the wrong end of the stick. Out of interest what do you mean by taping On 04/08/2025 at 17:37, puntloos said: with the Shingling method I am guessing: Bottom piece of tape Tape 2 above overlaps by say 15mm Tape 3 ditto Etc. That sort of thing?
Nickfromwales Posted August 11, 2025 Posted August 11, 2025 Firstly, the info needed is the hole size, the dia of the thing going through the hole, and then the size/area/diameter of whatever it is that's getting affixed to the external rendered wall. Externally you just need to be weatherproof, and the only airtightness needs addressing at the AT layer internally; usually doing a job like this retrospectively commands the use of FM330 foam as the means to the end, as it insulates, is weathertight, and is airtight, plus it conforms to the gaps and voids left to complete the task. I've made a LOT of houses airtight, and then we've had the client "reconsider some options I gave them from day dot....." and then I've had to make new penetration(s) through a plastered, painted, AT wall, so I am quite familiar with doing this tbh. Just needs an eye on it or any 3rd party you entrust this to.
puntloos Posted September 16, 2025 Author Posted September 16, 2025 Thanks @Redbeard and @Nickfromwales - so sorry I left this for a while./ The thing going through is a R32 AC pipe, which typically is perhaps 5cm diameter. Yes there's render, k-rend. My main problem is that now the house is effectively finished and we're retrofitting one more AC, they have only very little interest to come over.. they will, but "in their own good time" which could be ages from now. Should I perhaps just buy FM330 foam, spray the hell out of the hole the AC team leaves, and then hope someone comes in later and does it properly? My wall buildup is attached:
Redbeard Posted September 26, 2025 Posted September 26, 2025 Biggest problem I can see is that for your repair (unless the original contractor has the remnants of the coloured render they used) you could need: 25kg base-coat and a 25 ltr tub of top-coat (and thoretically some primer too!)
JohnMo Posted September 26, 2025 Posted September 26, 2025 CT1 either end of the hole. Internally allow for a skim of filler if you see the pipe, otherwise CT1. Ideally the hole should have a liner. So CT1 in place and CT1 the gap for the pipe.
