AnnaKH Posted August 4, 2025 Posted August 4, 2025 Hi, I'm looking for advice on how best to mount a monobloc tap on a 22mm laminate worktop. I had hoped to get a thicker worktop but due to stock and needing to complete asap, I've opted for the thinner one. Are there brackets? mounting plates? something that will help secure the tap and cause as little damage to the worktop as possible? Thanks for any advice!
Nickfromwales Posted August 4, 2025 Posted August 4, 2025 22mm chipboard with thin laminate, or 22mm solid laminate?
JohnMo Posted August 4, 2025 Posted August 4, 2025 32 minutes ago, AnnaKH said: how best to mount a monobloc tap on a 22mm laminate worktop Can you not mount in the sink?
AnnaKH Posted August 4, 2025 Author Posted August 4, 2025 1 hour ago, Nickfromwales said: 22mm chipboard with thin laminate, or 22mm solid laminate? The worktops are Spectra Square Edge laminate - BS/EN438 laminate surface bonded to EN312/2003 E1 high density particle board.
AnnaKH Posted August 4, 2025 Author Posted August 4, 2025 1 hour ago, JohnMo said: Can you not mount in the sink? No - I bought a narrow edge stainless steel drop-in sink. I'm willing to admit that in my decision-fatigue, I went with what I liked the look of instead of what might be most practical!
Nickfromwales Posted August 4, 2025 Posted August 4, 2025 With such a thin particle board worktop, the risk is over tightening the tap and it slowly compressing itself into the surface. Is the tap a standard diameter unit? So a 28-30mm hole give or take?
AnnaKH Posted August 4, 2025 Author Posted August 4, 2025 Thanks for your feedback. Here's the spec of the tap - https://cdn.shopify.com/s/files/1/0222/7290/1216/files/Ellsi-PDT-000014-datasheet.pdf?v=1672825838 Height (mm) 295 Width (mm) 210 Length / Depth (mm) 45 Inlet Connection: 1/2” BSP Flexible Tails Tap Hole Diameter: 35mm I was looking at stainless steel deck plates to mount the tap onto on the surface of the worktop - might that help?
Temp Posted August 5, 2025 Posted August 5, 2025 10 hours ago, AnnaKH said: I was looking at stainless steel deck plates to mount the tap onto on the surface of the worktop - might that help? and or find some 35mm ID Stainless Steel pipe and epoxy a 22mm length into a hole to suit the OD to prevent the worktop being crushed. Whatever you decide I would paint something on the walls of the hole to stop water affecting the worktop.
