JBASport Posted August 3, 2025 Posted August 3, 2025 A delay in funding for the project meant a significant delay in commencement. We had about 40 Sheets of foiled backed plasterboard stacked, foil against foil. We are not sure what has happened but the sheets are stuck together 2 at a time, foil to foil. Is there a way we can separate them without causing damage to the sheets? Thankyou in advance for any advice. Terry
Nickfromwales Posted August 3, 2025 Posted August 3, 2025 What have you tried so far to separate them? Can you get a corner apart? May be one to run by the builders merchants in case they’ve dealt with this problem in house / other.
nod Posted August 3, 2025 Posted August 3, 2025 Set a heater blower up a couple of meters away to loosen them
JBASport Posted August 4, 2025 Author Posted August 4, 2025 I can get an edge up but you can see that if I tried to lift it any further the board will start to crack. I have tried heat, but that seem to work either. Although under cover in an open extension I think it must have been a damp environment that caused the sheets to stick together. Terry
torre Posted August 4, 2025 Posted August 4, 2025 If it's foil to foil that's stuck, rather than paper, and you can get a corner up you could try pulling a length of string held at both ends between the boards to break what may just be surface tension between them. Like using a wire to cut a clay pot off a wheel. If the foil gets slightly damaged you could aluminium tape to repair or use a separate VCL if you're relying on the foil for that purpose. Some lower in your pile may not be as tightly stacked anyway.
