Mikey_1980 Posted December 29, 2017 Share Posted December 29, 2017 Hi, does anyone know if is possible to get something similar to the below, but instead of two sockets one is a switched spur and the other a normal socket? https://www.screwfix.com/p/schneider-electric-converta-socket-1-gang-to-2-gang-polycarbonate/12849?tc=CA2&ds_rl=1248181&ds_rl=1245250&ds_rl=1249481&gclid=EAIaIQobChMIt4-2k-iv2AIVp7DtCh3CagB0EAQYASABEgKkdvD_BwE&gclsrc=aw.ds&dclid=COC3osfor9gCFTKI7QodSwMHPw Link to comment Share on other sites More sharing options...
Onoff Posted December 29, 2017 Share Posted December 29, 2017 Can't think off the top of my head but how about a surface mount dual box positioned over the 1G existing? Link to comment Share on other sites More sharing options...
Jeremy Harris Posted December 29, 2017 Share Posted December 29, 2017 Have you got a single or double gang box in the wall, and is it currently wired to a ring final? What you've linked to is a conversion outlet, that fits a single gang box. Your best bet would be to fit a second single gang box alongside and use that to connect up the FCU. A word of caution, how many spurs do you already have on that ring final? Link to comment Share on other sites More sharing options...
Mikey_1980 Posted December 29, 2017 Author Share Posted December 29, 2017 (edited) Hi, its just a single gang box at the moment, which is a switched spur for a built in dishwasher. I just wanted to add a socket to run a coffee machine because it’s the most convienient location. And its in a a tiled wall which is why I was looking at the conversion plates. Edited December 29, 2017 by Mikey_1980 Link to comment Share on other sites More sharing options...
Jeremy Harris Posted December 29, 2017 Share Posted December 29, 2017 So, is it a spur or is in part of the ring final? Easy way to check is whether or not there are two cables going in to it, if there are then it's part of the ring final, if they aren't then it's already a spur and you ideally need to find where that spur is fed from. Link to comment Share on other sites More sharing options...
Onoff Posted December 29, 2017 Share Posted December 29, 2017 7 minutes ago, JSHarris said: So, is it a spur or is in part of the ring final? Easy way to check is whether or not there are two cables going in to it, if there are then it's part of the ring final, if they aren't then it's already a spur and you ideally need to find where that spur is fed from. Erm...two cables could just mean it's a a spur feeding a spur! Link to comment Share on other sites More sharing options...
Jeremy Harris Posted December 29, 2017 Share Posted December 29, 2017 Just now, Onoff said: Erm...two cables could just mean it's a a spur feeding a spur! Very true - forgot that possibility! Still need to know if this is really a spur off the ring final or a separate spur taken off somewhere else, or a part of the ring final, though. I'm not wholly comfortable giving blind suggestions without knowing where that single gang socket is currently fed from, as it may well have been added at some time when the dishwasher was fitted, and I've seen all sorts of wonderful jobs like that, including a spur fed directly from the non-switched side of a 45 A cooker switch............... Link to comment Share on other sites More sharing options...
Onoff Posted December 29, 2017 Share Posted December 29, 2017 (edited) AEI USED TO do what you want: https://www.flameport.com/electric_museum/sockets_13A_BS1363/aei_socket_with_fused_outlet.cs4 I'd go surface dual pattress box carefully positioned over the old one. You can get them different depths: https://www.ukelectricalsupplies.com/Click-Dual-29mm-Surface-Pattress-Box.htm?utm_source=google&utm_medium=shop&utm_campaign=feed&gclid=EAIaIQobChMIt8jgovKv2AIVab7tCh1WgAB9EAQYAiABEgJF3PD_BwE Then a 1G socket and separate switch. EDIT: It will be proud off the wall!!! Or bite the bullet and let in a dual back box. Edited December 29, 2017 by Onoff Link to comment Share on other sites More sharing options...
Mikey_1980 Posted December 29, 2017 Author Share Posted December 29, 2017 Thanks all, I will have a play with a double gang box for now and see if it will work. It’s a new build flat, approximately 6 years old so the electrics are all standard nothing has been altered or played with since it’s been built. Link to comment Share on other sites More sharing options...
