HughF Posted Monday at 17:08 Posted Monday at 17:08 What’s the Service schedule for anodes in a glass lined cylinder/heater? I’ve got one (a styleboiler ecosyn80) at my off-grid property and I’m curious to know when I need to change it. Manufacturer’s instructions are somewhat lacking.
JohnMo Posted Monday at 17:14 Posted Monday at 17:14 From other manuals I have read it varies between annual and every two years. I would do it annually, then you will get to know what the material loss is like. 2
Nickfromwales Posted Monday at 18:36 Posted Monday at 18:36 Yup. Defo do not push your luck here, as the anode stops the cylinder corroding at the unions. Ariston used to sell a lot of glass lined UVC’s back in the day, and I went to a lot which looked A1 but we’re leaking into the insulation jacket via what you couldn’t see. They rot from the inside out btw.
