Pocster Posted Monday at 17:04 Posted Monday at 17:04 (edited) So this crap battery powered high water alarm worries me . Just tested it , batteries apparently flat even though replaced only 3 weeks ago . Not much faith in this . Could be flat and I wouldn’t know until kitchen flooded So want a pressure switch that links to a mains powered but battery backup unit . Unit has a light to indicate it’s actually on and also possibility to trigger a zigbee relay so can notify HA Most of these alarms operate on a float which I don’t want . Pressure switches seem to be industrial or maybe a washing machine type pressure switch ??? Any solid suggestions on a pressure switch , alarm box that will work together suitably appreciated Edited Monday at 17:06 by Pocster
Pocster Posted Monday at 17:23 Author Posted Monday at 17:23 Maybe this alarm box ? https://www.tritoncontrols.co.uk/alarms-and-controls/basic-alarm-easyfit.html?ppc_keyword=&gad_source=1&gad_campaignid=12120096619&gbraid=0AAAAACdOt02h4JZ2Q8Pdc71YfcucXK6V4&gclid=CjwKCAjw1dLDBhBoEiwAQNRiQThOWqB0p_yPqPWb-ZbaDP_56QCHJGeU_7bjHp0DB25wdPJVVM12UBoC-98QAvD_BwE But a suitable pressure sensor switch seems to be a bit of a minefield of possibilities
Mr Punter Posted Monday at 17:40 Posted Monday at 17:40 I don't understand where the pressure switch would fit in. It is normally float type switches for these applications.
Pocster Posted Monday at 17:47 Author Posted Monday at 17:47 5 minutes ago, Mr Punter said: I don't understand where the pressure switch would fit in. It is normally float type switches for these applications. The saniflo has a pressure switch . You drill a hole in the top of the saniflo , place a plastic tube it it . The saniflo then sits ontop the unit with the pressure switch in the head of the tube .
Pocster Posted Monday at 19:15 Author Posted Monday at 19:15 So I’m going to use a standard phone charger to a usb step down I.e to 3v . Wire it into a zigbee door sensor . Then wire dry contacts from reed switch to alarm panel . This should get reliable HA in event of the alarm . Its just the pressure sensor - might take a punt .
Pocster Posted Tuesday at 13:20 Author Posted Tuesday at 13:20 Great website ! https://www.silicon-ark.co.uk I found https://www.silicon-ark.co.uk/PSF100A-0-5-Pressure-switch-by-multicomp?search=Pressure
