YorkieSelfBuild Posted July 4 Posted July 4 Hi, as title says, is one light fitting enough for a large bedroom, 5 x 3m? I thought one would be enough with a bright bulb plus floor lamp and bedside lamps but that was before I researched lighting, light calculators, etc. Electrics already done with one fitting in centre of room. I would want 2 evenly spaced but I have no idea how much work or money that would take. Have I boobed massively?
ProDave Posted July 4 Posted July 4 We have one light fitting in our 5M by 4M bedroom. It is a high ceiling with a light fitting that hangs down a long way with 3 lamps in it. Works no problem. How easy to change at this stage? What is above? Accessible loft space, easy peasy. Vaulted ceiling with just a small service void could be very difficult.
YorkieSelfBuild Posted July 4 Author Posted July 4 Ceiling is vaulted, 2.4m high. The ensuite has a sloped ceiling (I'm trying to remember the details) and builder says they drilled through the beam so likely difficult and/or costly to change it now :( I did look at light fittings with multiple sockets for the dining table, looks like I'll need something similar in the bedroom. Maybe like this, 40W per socket would work? https://www.illumination.co.uk/pintacura-pendant-light-h3613719.html#product-attributes And thanks for the reply, self build is stressful, making all these decisions, especially in areas I know nothing about. I need the architect or builder to tell me when my ideas are bad, unworkable or needs more research!
ProDave Posted July 4 Posted July 4 Do you mean 2.4m? That is low for the apex of a vaulted ceiling and would not be high enough for that sort of multi pendant fitting.
YorkieSelfBuild Posted July 4 Author Posted July 4 D'oh, that's the kitchen ceiling height. I've asked what it is for this bedroom
YorkieSelfBuild Posted July 7 Author Posted July 7 Ceiling is 3.3m, light fitting will be slightly lower than that. I think the ceiling is sloped, not vaulted, will check today during site visit
Temp Posted July 7 Posted July 7 On 04/07/2025 at 10:30, YorkieSelfBuild said: Hi, as title says, is one light fitting enough for a large bedroom, 5 x 3m? I thought one would be enough with a bright bulb plus floor lamp and bedside lamps I think it will be fine. Similar to what we have.
YorkieSelfBuild Posted July 7 Author Posted July 7 Crisis over! Ceiling is vaulted, high enough for multi bulb fitting and the light I linked to can cut the cables shorter. But also caught in time to add extra bulkhead light furthest away from windows.
