YorkieSelfBuild Posted July 4, 2025 Posted July 4, 2025 Hi, as title says, is one light fitting enough for a large bedroom, 5 x 3m? I thought one would be enough with a bright bulb plus floor lamp and bedside lamps but that was before I researched lighting, light calculators, etc. Electrics already done with one fitting in centre of room. I would want 2 evenly spaced but I have no idea how much work or money that would take. Have I boobed massively?
ProDave Posted July 4, 2025 Posted July 4, 2025 We have one light fitting in our 5M by 4M bedroom. It is a high ceiling with a light fitting that hangs down a long way with 3 lamps in it. Works no problem. How easy to change at this stage? What is above? Accessible loft space, easy peasy. Vaulted ceiling with just a small service void could be very difficult.
YorkieSelfBuild Posted July 4, 2025 Author Posted July 4, 2025 Ceiling is vaulted, 2.4m high. The ensuite has a sloped ceiling (I'm trying to remember the details) and builder says they drilled through the beam so likely difficult and/or costly to change it now :( I did look at light fittings with multiple sockets for the dining table, looks like I'll need something similar in the bedroom. Maybe like this, 40W per socket would work? https://www.illumination.co.uk/pintacura-pendant-light-h3613719.html#product-attributes And thanks for the reply, self build is stressful, making all these decisions, especially in areas I know nothing about. I need the architect or builder to tell me when my ideas are bad, unworkable or needs more research!
ProDave Posted July 4, 2025 Posted July 4, 2025 Do you mean 2.4m? That is low for the apex of a vaulted ceiling and would not be high enough for that sort of multi pendant fitting.
YorkieSelfBuild Posted July 4, 2025 Author Posted July 4, 2025 D'oh, that's the kitchen ceiling height. I've asked what it is for this bedroom
YorkieSelfBuild Posted July 7, 2025 Author Posted July 7, 2025 Ceiling is 3.3m, light fitting will be slightly lower than that. I think the ceiling is sloped, not vaulted, will check today during site visit
Temp Posted July 7, 2025 Posted July 7, 2025 On 04/07/2025 at 10:30, YorkieSelfBuild said: Hi, as title says, is one light fitting enough for a large bedroom, 5 x 3m? I thought one would be enough with a bright bulb plus floor lamp and bedside lamps I think it will be fine. Similar to what we have.
YorkieSelfBuild Posted July 7, 2025 Author Posted July 7, 2025 Crisis over! Ceiling is vaulted, high enough for multi bulb fitting and the light I linked to can cut the cables shorter. But also caught in time to add extra bulkhead light furthest away from windows.
