Cadoxton Jack Posted June 29, 2025 Posted June 29, 2025 Span for joists is 3m including overhang of 300mm. I intend fixing furrings on top of joists to provide the slope. i understand that the thin edge of the furring should be fixed 5-10mm above joist to prevent ponding. Is this correct? Should I fit fascia’s before osb boards or after them and should fascia boards butt up level against top of osb or butt up below osb boards. Intend fitting an epdm rubber roof. Thanks KeithÂ
Nickfromwales Posted June 29, 2025 Posted June 29, 2025 1 hour ago, Cadoxton Jack said: Span for joists is 3m including overhang of 300mm. I intend fixing furrings on top of joists to provide the slope. i understand that the thin edge of the furring should be fixed 5-10mm above joist to prevent ponding. Is this correct? Should I fit fascia’s before osb boards or after them and should fascia boards butt up level against top of osb or butt up below osb boards. Intend fitting an epdm rubber roof. Thanks Keith A pic would really help. We'd need to see where water was supposed to head so it can discharge into the downpipes.  If it all goes wrong I'm only 20 mins from you so can drop some wellies off Â
Nickfromwales Posted June 30, 2025 Posted June 30, 2025 1 hour ago, Cadoxton Jack said: Very helpful 😡 9 hours ago, Nickfromwales said: A pic would really help. We'd need to see where water was supposed to head so it can discharge into the downpipes. ?
elite Posted June 30, 2025 Posted June 30, 2025 11 hours ago, Cadoxton Jack said: i understand that the thin edge of the furring should be fixed 5-10mm above joist to prevent ponding. Is this correct? I'm not sure what you are proposing here - can you post a diagram / photo? Â I have just replaced a roof on an outbuilding (no furring), this was my buildup: Joist -> OSB -> VCL -> Insuation -> OSB -> Rubber Fascias were fitted after the deckÂ
ToughButterCup Posted June 30, 2025 Posted June 30, 2025 9 hours ago, Nickfromwales said: A pic would really help..... Â A picture is worth a 1000 words - helps us to help you....
marshian Posted June 30, 2025 Posted June 30, 2025 No offence intended here but you’ve started several threads in specific sections related to your garden room project not everyone would have followed all of them.  I think the first post which you clearly didn’t was typical forum humour which sometimes doesn’t translate to new members.  a sketch or picture helps a lot to understand what you are trying to do - i have an EPDM roof on my shed that I completely rebuilt last year - it doesn’t pool but I made the fall a little too much as in a good shower it can shoot past the gutters. Previous felt covered OSB roof was much shallower pitch and it pooled and rotted out.
Cadoxton Jack Posted July 19, 2025 Author Posted July 19, 2025 Hi marshian im just a simple fellow looking for advice. Im not a builder just a diy enthusiast with time on my hands since I finished work. I didn’t expect sarcastic comments from some contributors. Yes my posts seem confusing as I’m thinking about all the tasks that need to be done. I’m not a builder but I’m planning each stage carefully to get it right and was just reaching out for help and advice. I’ve posted again tonight with question about when to fit fascia’s for epdm roof - I’m hoping for a better experience this time.Â
