Nickfromwales Posted July 11, 2025 Posted July 11, 2025 3 hours ago, nod said: I’m pretty sure the people moving into them will appreciate our efforts Which makes us both wonder why we got out of bed eh?? 😑
Spinny Posted July 12, 2025 Posted July 12, 2025 I am going for wet plaster and experience so far is... Discussed work with builder's plasterer multiple times because of concerns over the need for wet plastering skills etc and explicitly asked him - can you do X, can you do Y, can you deal with this wonky wall because the 1930's plaster I knocked off was plumb even where the wall isn't. Told yes, yes, yes etc. Builder told me 'he is a good plasterer'. Twas all shown to be lies when he started work. Where he skimmed a boarded partition wall it is fine. Where he has wet plastered it is crap. 15mm out of true over the top half of one wall. Even on a section of plumb new blockwork he has managed to be 10+mm out over 1.5m. Never saw him use a long straight edge as you can see people using on youtube. So, some builder's and tradies do lie, some do lie without hesitation. No doubt builders like cheap plasterers (possibly on job and knock terms). The only way to tell if they can do a proper job is to see their work - via reference job visits and/or having them do a small piece of work first so you can see their work first hand. Now have another plasterer starting work. Learning that it is key to spell out all detail re positioning of plaster lines against doors and windows etc. Where something is boarded it doesn't mean it is square or plumb. I am double checking all the beads now with a spirit level in 3 dimensions because the plaster will follow the beads, so it is imperative the beads are correctly positioned. (Builders plasterer's bead was put on in a curve - that wall is curved and has to be corrected). Some things inevitably cannot be made right but better to decide on compromises now rather than measure afterwards when it is too late. (Just had an existing internal door lining pulled out and replaced to facilitate getting a good plaster line). Watch out for recesses - I am going to have to suck up a shelving recess that is deeper one end than the other. Have found two adjacent lintels are not set level because one is thicker than the other. Now cannot be corrected because the trickle vent is in the way. I really don't like dot and dab because few of us have large houses and I just don't like the idea of planning stuff with an architect or a kitchen supplier only for someone to dot and dab every dimension smaller by an inch or two. Then kitchen people want 30mm 'packers' everywhere 'because builders cannot build plumb' and before your know it your kitchen is 6 inches shorter for no good reason.
Spinny Posted July 12, 2025 Posted July 12, 2025 (edited) Quote Maybe true if you go around your house hitting the walls - maybe some anger management is needed? If you want strong plasterboard, and plasterboard that that you can screw straight into and mount stuff to, it is available... https://youtu.be/nQK8awMOKpM?feature=shared https://youtu.be/nQK8awMOKpM?feature=shared https://youtu.be/Ure_nvPLYks?feature=shared https://youtu.be/CUvq0QzwDzY?feature=shared my favorite...https://youtu.be/HfVqIyUpE2M?feature=shared No builder is ever going to buy this for any customer unless you specify it and make them, It costs money and it is heavy. But IMO it makes perfect sense - the public should get what the public wants, not what a builder decides they can and can't have. The world needs to move forward. (I don't work for Gyproc, just like to see stuff that solves problems - I like my Frosti tap too. Edited July 12, 2025 by Spinny
Nickfromwales Posted July 12, 2025 Posted July 12, 2025 12 hours ago, Spinny said: the public should get what the public wants, not what a builder decides they can and can't have. The world needs to move forward. I always suggest to (tell) my customers to sit down with the builder, before they do anything, and set out your station. The builder will otherwise decide, if you appear to be a walk-over on day 1. They will assume fast=good; you can say "reasonable pace with a better eye of the quality and finish may cost another 5-10%, but I ACCEPT". Tell them that you're going to ask to have a framing level placed on the walls after they've been laid on, so they know that shite won't fly. Assume they'll do a good job, and you'll quickly find why folk say "assumption is the mother of all feck ups". Speak to the builders, they're human at the end of the day . Let the builder know that you're approachable, eg if more work needs doing to deliver a better end result. Employing a general builder, because their quote was the favoured one, isn't any means of a measure or guarantee as to what will be delivered, this needs to be managed (expectations from both sides) by you; if you wish to stand any chance of getting what you expect (want), then say this at the outset, not complain afterwards if you didn't ask what the quality / workmanship would be like. FYI, cement and skim are finishers not fillers, so a wall that's seriously out of plumb should probably have been dot & dabbed vs scratched and skimmed. 1
Dave Jones Posted July 13, 2025 Posted July 13, 2025 dot a dab for me. the airtightness game is already lost if your relying on a plasterer to fix it for you!
Bancroft Posted July 15, 2025 Posted July 15, 2025 On 12/07/2025 at 11:08, Spinny said: my favorite...https://youtu.be/HfVqIyUpE2M?feature=shared Excellent marketing!
