tommyleestaples Posted June 11, 2025 Posted June 11, 2025 Hi all, I had an extension done and one of the walls in the en-suite is thermalite which is nice and level. I need to board this wall out with insulated tile backer boards. I was planning to prime the thermalite wall with SBR Then apply a rapid set flexible cement based tile adhesive to the tile backer board with a 1/4 inch trowel and then fit the board to the wall. Once the tile adhesive has dried I was going to mechanically fix the board as well. Does this sound correct?
nod Posted June 12, 2025 Posted June 12, 2025 You can bed the tile board on But must mechanically fix once set BG do a knock in for this purpose
tommyleestaples Posted June 12, 2025 Author Posted June 12, 2025 Sorry what do you mean BG do a knock in for this purpose?
tommyleestaples Posted June 12, 2025 Author Posted June 12, 2025 Thanks will take a look. Just noticed Jackoboard do these fixings, I wonder how they would be with thermalite blocks
JohnMo Posted June 12, 2025 Posted June 12, 2025 Use fixing like these in thermolite blocks https://www.screwfix.com/p/dewalt-anchors-nylon-60mm-50-pack/454HT?gclsrc=aw.ds&gad_source=1&gad_campaignid=901249366&gbraid=0AAAAAD8IdPyrPaWtYCDl-12B6WyYxf6-9&gclid=CjwKCAjw9anCBhAWEiwAqBJ-cxkXAFu8EM2b6-pp6eH2onsHE_OPHgKWRQ9vbSiWb-nbnB_0IGEZchoCitcQAvD_BwE&gclsrc=aw.ds
Spinny Posted June 13, 2025 Posted June 13, 2025 Can these boards be used outside ? I have mentioned elsewhere I need to put 25mm XPS insulation against the outside blockwork under my bifolds to about 500-600mm underground to compensate for a problem with the internal upstand insulation. I noticed Fastwarm do a 30mm XPS sheet https://www.fastwarm.com/fastwarm-30mm-xps-insulation-boards-11115-p.asp But when I spoke to them about it they suggested using tile backer board... https://www.fastwarm.com/fastwarm-30mm-tile-backer-insulation-board-11095-p.asp
