Dan1983 Posted June 3 Posted June 3 Afternoon all, Another question if anyone has experience I’m looking to use recessed lights in my sleeper retaining wall The wall will be 3 sleepers high, for ease of any issues I’m thinking I should install the lights in the top course of sleepers to keep things accessible? The retaining wall is opposite the kitchen and lounge which both have bi-folds. If I go with a standard type spot light with a 3000k- warm white LED do you think this would cause glare and be too bright? Other option is I use a down lighter which would look nice but guessing won’t light up much of the actual patio space?
Dan1983 Posted June 3 Author Posted June 3 Also has anyone had a bespoke wiring harness made before? can’t really see anything g off the shelf that is going to work with our lay out
Spinny Posted June 4 Posted June 4 Maybe you could use some smart lighting and then you could adjust the colour temperature and brightness to suit. Here is one that does some zigbee stuff... https://uk.paulmann.com/smart-home/zigbee/outdoor-luminaires/ I have never used these though, so just an example, no actual experience to recommend this company or not. My outdoor lights are just a multicore armoured cable in the ground at the moment.
