Dan1983 Posted June 2 Posted June 2 Evening all Ive had my RSJs delivered and they are starting to be installed but I don’t think the corner posts are correct Would there be a reason for them to be made in this way?
Temp Posted June 2 Posted June 2 (edited) Perhaps intended to allow a bit of timber vertically in the corner? Reduces the visual impact of the RSJ? Edited June 2 by Temp 1 1
Onoff Posted June 2 Posted June 2 8 minutes ago, Temp said: Perhaps intended to allow a bit of timber vertically in the corner? Reduces the visual impact of the RSJ? My first thought that. 1
Dan1983 Posted June 2 Author Posted June 2 It’s not so bad in that orientation but thinking it will look odd when they are the opposite way round for the steps in the middle of the wall as it will skew/ offset everything Will ask in the morning if there was a reason as only one cemented in so far It will really bug me i think Got 6 of them and non refundable I think 😂
Temp Posted June 2 Posted June 2 6 minutes ago, Dan1983 said: It’s not so bad in that orientation but thinking it will look odd when they are the opposite way round for the steps in the middle of the wall as it will skew/ offset everything.. There are different ones for joining sleepers end to end in the middle of a wall.. https://www.aafencing.co.uk/products/rsj-railway-sleeper-post-raw-steel-intermediate?gad_source=1&gad_campaignid=21969916683&gbraid=0AAAAAprPxhDFXMV1bmBp3GKe2A1QdfyEr&gclid=CjwKCAjwl_XBBhAUEiwAWK2hzhe1gySsQvH_494A0E-RH3DyJF19IegcNOGjkPMJk5YEj36gQ4DwOxoCdg8QAvD_BwE I can't immediately see what you use for a T joint. Perhaps you have to bolt two of the above together?
Dan1983 Posted June 2 Author Posted June 2 Will be the same as the corner posts but will look like this from the front
Dan1983 Posted June 3 Author Posted June 3 All sorted Had an issue with one of the posts so had all the other ones replaced how I wanted The one installed will remain and will use the same style at the other end then tie the sleeper flower bed in by notching the end of the first sleeper like below
