Can anyone recommend some under cabinet lights for a kitchen? Ideally...
Low profile <25mm Tall (so not T5 which tend to be 30-33mm. The recess is only 28mm deep)
Mains powered or "plug-in"
Approx 40-45cm long to fit 50cm wide cabinets. A 30cm version would be good as well.
Ideally just simple lights without hand waving controls. If it has that does it default to ON (or remember it was ON?) when you disconnect and reconnect the power? I want to use a wall switch to turn a set on/off without having to go around hand waving under each one.
7 minutes ago, Nickfromwales said:
Lowest profile will be a led strip?
This.
 Led strip in an aluminium profile with diffuser, cut to length.
Was hoping to avoid rolling my own but that might turn out to be easier.
I did find one fitting at a local BnQ that was perfect (even got adjustable angle) but they seem to have discontinued the lengths I need.
