Marvin Posted May 2, 2025 Posted May 2, 2025 Please can you tell me what the best way is to approach insulating an old 2 up 2 down solid brick wall house external walls. Slap a coat of PIR on the plaster? Seal the wall first? Batten out? Strip plaster? Insulated plasterboard? Help, thoughts appreciated. Thanks Marvin
Redbeard Posted May 2, 2025 Posted May 2, 2025 I usually seal the wall with a lime parge coat. Although it is often not done this is quite important if using PIR (I wouldn't, usually), as the condensation risk assessments you get from the PIR manuf'rs will usually assume very good breathability *outwards* through the wall, on account of having closed the breathability path off completely with 2 sheets of foil. If the existing plaster is lime-based you may get away with leaving it, and augmenting where it never was (often behind skirtings, for example, and between Ground and 1st floors). Just make sure to strip off any non-breathable coatings. I tended to use wood-fibre a lot more than PIR. Yes, it is expensive, but much better at 'managing' moisture from the room. Even if you decide to use PIR I would strongly recommend using PIR *and plasterboard*, but not bonded. Yes, each sheet of insulated plasterboard has a VCL, and when you join them together, they don't! If you use separate PIR (or other insulation) and VCL you can tape the life out of the PIR before adding the plasterboard. Yes, wood fibre is only about half the insulation value of PIR but is so much better in many ways. And it does not give off cyanide when it burns. 1
nod Posted May 2, 2025 Posted May 2, 2025 Ideally you will need to tank the walls firs None of the Parge or lime will do this There are some very good slurry tanking on the market that won’t break the bank Then dot and dab insulated PB (pink) Followed with a gypsum mechanical fixing 1
Marvin Posted May 3, 2025 Author Posted May 3, 2025 (edited) 10 hours ago, nod said: Ideally you will need to tank the walls firs None of the Parge or lime will do this There are some very good slurry tanking on the market that won’t break the bank Then dot and dab insulated PB (pink) Followed with a gypsum mechanical fixing Hi @nod I assume you would remove existing plaster first? Edited May 3, 2025 by Marvin
nod Posted May 3, 2025 Posted May 3, 2025 1 hour ago, Marvin said: Hi @nod I assume you would remove existing plaster first? Yes it’s worth spraying a salt inhibitor on also Really cheap and quick 1
Marvin Posted May 13, 2025 Author Posted May 13, 2025 On 03/05/2025 at 09:19, nod said: Yes it’s worth spraying a salt inhibitor on also Really cheap and quick Hi @nod As it's a two story building do you have to run the tanking up the walls between the ground floor ceilings and the first floor flooring? (if so presumably by removing some of the ceiling board or flooring or both??)
nod Posted May 13, 2025 Posted May 13, 2025 28 minutes ago, Marvin said: Hi @nod As it's a two story building do you have to run the tanking up the walls between the ground floor ceilings and the first floor flooring? (if so presumably by removing some of the ceiling board or flooring or both??) I would do both floors But stop short at taking floorboards up 1
Mike Posted May 13, 2025 Posted May 13, 2025 On 02/05/2025 at 22:09, Marvin said: Please can you tell me what the best way is to approach insulating an old 2 up 2 down solid brick wall house external walls. There's a meandering but useful thread on a similar topic here: 1
