iMCaan Posted April 9, 2025 Posted April 9, 2025 Hi We are fitting LVT in a new bathroom. Should the LVT (herringbone - click type) be put under or around the toilet and basin pedestal? Both toilet and basin with full pedestal are not yet fitted. Thanks
Mr Punter Posted April 9, 2025 Posted April 9, 2025 Under is much better. You can temp remove the sink and WC while they fit the floor.
Conor Posted April 10, 2025 Posted April 10, 2025 You can temporarily wedge the toilet up on some wooden blocks and slip the lvt under. Assumes you have a Flexi supply pipe. You only need 40mm or so.
iMCaan Posted April 11, 2025 Author Posted April 11, 2025 Thanks @Conor Yes, it's flexi supply pipe. The toilet is not yet fitted to supply so I'll run the herringbone lvt completely under it. Thanks
