umiq88 Posted March 26 Posted March 26 In the process of wiring and getting UFH installed in a couple of weeks. Layout is 4 bed Bungalow and wondering about theromstats Plan is to have everything except the bedrooms on 1 zone and 1 thermostat per bedroom. The whole system should work off weather compensation but I want the option to have the bedrooms a little colder if need be or I have an older person in the family staying over. Where is the best location for the main thermostat controlling the whole house?
Benpointer Posted March 26 Posted March 26 I'm no expert but I'd have thought the main living area is the obvious place. We're currently in a rather drafty rented place that is impossible to keep at a sensible temperature - it's either too hot or too cold. It's got oil-fired CH with rads in every room. The boiler/pump is controlled by a single wireless thermostat that you can move to wherever you like. This suggests two things to me: I am not convinced a single thermostat controlling a whole house or most of a house is a good thing. If you're going to have one and can't decide where to place it, how about a mobile wireless stat, then you can decide where it works best in practice?
JohnMo Posted March 26 Posted March 26 On 26/03/2025 at 20:40, umiq88 said: weather compensation Expand Not a fan of zoned heating systems especially after removing them all and reducing running costs by over 50%. Your issue is one zone calls for heat with everything off, boiler or heat pump just cannot cope, so short cycling is prevalent. Balance can adjust room temps For a control thermostat just have a wireless one and move it about to get the best location - ours is in the hall, but doesn't mean it's ideal for you.
