I have prepared one in part but am struggling to complete. Does anyone have one I can use to help me finish and get the demolition notice submitted?
Thanks for any help.
From this part;
Mechanical Demolition:
Equipment: Identify the type of equipment to be used (e.g., excavator, demolition hammer, etc.).
Technique: Describe the demolition method, including whether it will be top-down or bottom-up, and how the structure will be taken down.
Control Measures: Outline measures to prevent premature collapse or the collapse of adjacent buildings, including the use of temporary supports and safety barriers.
Debris Management:
Debris Zones: Identify designated areas for storing debris and outline how debris will be removed from the site.
Removal: Describe how debris will be loaded and transported to the disposal site, ensuring safe handling and preventing dust and debris from escaping.
V. Safety Procedures
Personal Protective Equipment (PPE):
Specify the required PPE for all personnel on site, including hard hats, safety glasses, gloves, and high-visibility clothing.
Training:
Ensure all personnel are adequately trained in safe demolition practices and the use of equipment.
Emergency Procedures:
Outline emergency procedures, including first aid, fire safety, and evacuation procedures.
Exclusion Zones:
Establish and clearly mark exclusion zones around the demolition area to prevent unauthorized access.
Hard-Hat Areas:
Identify hard-hat areas and ensure they are clearly marked.
Noise Control:
Implement measures to control noise levels, such as using noise barriers and ear protection.
  • 3 months later...
On 18/03/2025 at 15:12, Rosslyn said:
From this part;
Debris Management:
Training:
Exclusion Zones:
Hard-Hat Areas:
Noise Control:
Please change where needed.
Equipment:
Demolition will be carried out using suitable heavy machinery, including a tracked excavator equipped with a hydraulic demolition hammer and/or grapple attachment. Additional equipment such as skid steer loaders may be used for material handling.
Technique:
The demolition method will follow a top-down approach to maintain structural stability. Load-bearing elements will be systematically dismantled starting from the roof, progressing down to the ground floor. The structure will be taken down in sections to maintain control and reduce the risk of sudden collapse.
Control Measures:
  • Temporary supports (e.g., props or bracing) will be installed as required to stabilize remaining structures during phased demolition.
  • Safety barriers and fencing will be placed around the demolition perimeter to restrict access.
  • Structural assessments will be conducted prior to and during demolition to ensure the safety of adjacent buildings.
  • A spotter or supervisor will monitor the site continuously for signs of instability.
Debris Management
Debris Zones:
Designated debris stockpiling zones will be located within the site boundary, away from the demolition edge and access routes. These zones will be clearly marked and kept organized to facilitate safe material handling.
Removal:
Debris will be loaded using mechanical equipment into covered or enclosed vehicles to minimize dust and material loss during transport. Dust suppression methods, such as water spraying, will be employed during loading. All waste will be taken to an approved disposal or recycling facility in accordance with environmental regulations.
Safety Procedures
All personnel must wear the following PPE:
  • Hard hats
  • Safety glasses or face shields
  • High-visibility vests/clothing
  • Steel-toe boots
  • Cut-resistant gloves
  • Hearing protection (when working near noise-emitting equipment)
Training:
All workers will be trained and certified in:
  • Safe demolition practices
  • Use and maintenance of demolition equipment
  • Site-specific health and safety procedures
    Toolbox talks will be conducted daily before work begins.
Emergency plans will be clearly communicated and include:
  • First aid stations and trained responders on-site
  • Fire extinguishers placed in accessible locations
  • Evacuation routes marked and kept clear
  • An incident reporting system for near-misses or hazards
Exclusion Zones:
Exclusion zones will be set up around active demolition areas, clearly marked with signage and physical barriers. Only authorized personnel may enter these zones.
Hard-Hat Areas:
The entire demolition site will be designated as a hard-hat area, with visible signs posted at entry points and reinforced during site inductions.
Noise Control:
Noise levels will be managed through:
  • Use of sound-absorbing barriers where needed
  • Limiting high-noise operations to daytime hours
  • Ensuring all personnel in high-noise zones wear hearing protection
  • Equipment maintenance to minimize mechanical noise output
Edited by Markuz
I'm not familiar with one of these, but are there other hazards you need to address?
  • Asbestos?
  • Electricity supply isolation?
  • Gas supply isolation?
Equipment:
Technique:
Control Measures:
Debris Management
Debris Zones:
Removal:
Safety Procedures
  • Hard hats
  • Steel-toe boots
Training:
Exclusion Zones:
Hard-Hat Areas:
Noise Control:
Ummm, is this buzzword bingo?
