Diarmid Posted March 8, 2025 Posted March 8, 2025 Looking to replace lpg heating system (underfloor heating) with ASHP combo. House is end terraced cottage about 120m2. Insulation 150mm PIR all round and triple glazed. Had a couple of quotes and one interests me in particular. ASHP + Thermino xPlus + 5kw battery + solar array, the rep mentioned a COP of 4.0 and expressed confidence in this, which surprised me? I thought COP of such systems were compromised by the need to run high water temperatures back to the 'tank' Grateful for opinions...
JohnMo Posted March 8, 2025 Posted March 8, 2025 Would definitely think of the systems as separate, ASHP and then PV and battery. CoP of 4 is realistic, if running on weather compensation. 20 minutes ago, Diarmid said: thought COP of such systems were compromised by the need to run high water temperatures back to the 'tank' What are you refering to as tank? The domestic hot water cylinder or something else? Also assume by 5kw battery you mean a 5kWh battery. That is pretty small when coupled to an ASHP especially when cold outside. So during winter months the PV is pretty rubbish, your battery will mostly be charged from the grid. On a cold day with normal house consumption and ASHP, battery will be good for 3 to 4 hours max from fully charged.
SteamyTea Posted March 8, 2025 Posted March 8, 2025 Welcome. As you are already living in the house, do you know your current energy usage? As you are on LPG, this could be a bit tricky to work out at first, but should be possible to calculate reasonably well. 49 minutes ago, Diarmid said: the rep mentioned a COP of 4.0 and expressed confidence in this, While very possible, I would never trust a company rep. What you need to know is the sCoP (seasonal coefficient of performance) as this is what your cash is really buying.
Diarmid Posted March 8, 2025 Author Posted March 8, 2025 just found this which confirms my scepticism
Diarmid Posted March 8, 2025 Author Posted March 8, 2025 usage is 1400l lpg per annum which I think equates to 10000kwh
SteamyTea Posted March 8, 2025 Posted March 8, 2025 8 minutes ago, Diarmid said: usage is 1400l lpg per annum which I think equates to 10000kwh Close enough, and 60 to 70% will be used in the heating season, but don't forget that the real efficiency of a gas boiler is lower than the stated efficiency, so possibly 25% goes waste.
JohnMo Posted March 8, 2025 Posted March 8, 2025 17 minutes ago, Diarmid said: just found this which confirms my scepticism Good design is key, good design is a very simple system. Start adding buffer, LLH and loads of zones, you get rubbish CoP, not in all cases but most. If you have UFH, system should look like this ASHP, flow connected to 3 port diverter valve, one side to cylinder coil other to UFH manifold, return pipes tee together and go back to ASHP. The manufacturers controller. Had the ASHP running yesterday all electric from excess PV for 6hrs at an average CoP of 5. 1
sharpener Posted March 8, 2025 Posted March 8, 2025 2 hours ago, Diarmid said: usage is 1400l lpg per annum which I think equates to 10000kwh So a 3.4 kW HP using this method. 3 hours ago, Diarmid said: Thermino xPlus This is not a good idea IMO. The phase change temperature of 58C means they need a flow temp of ~ 65 which knackers the efficiency, also there have been many reliability problems mentioned on this forum over the years. Better to have a horizontal tank under the eaves if you are really tight on space for a HW tank, though the stratification will not be as good. If you have smart meter and can get Octopus Cosy your battery can do 3 round trips a day but even so a 5kWh battery is not going to last long enough to ride out the evening peak 1600 - 1900h.
RobLe Posted March 8, 2025 Posted March 8, 2025 Re the battery size: For comparison we are an all electric house, and use 2000kWh of electric/year for house and hot water heating (via a heatpump). I think you’ll be similar or slightly higher than us. We have a 15kWh home battery, it copes for all but 5-10 days a year, on those days we have to import a few kWh of expensive electric, the rest of the time we’re on IOG electric.
DamonHD Posted March 8, 2025 Posted March 8, 2025 I am using a Thermino *alongside* my heat pump DHW tank, and I don't expect to be paying to import much electricity between now and September to make DHW... https://www.earth.org.uk/reconnecting-the-16WW-heat-battery.html
SteamyTea Posted March 8, 2025 Posted March 8, 2025 @Jeremy Harris was going to fit a small cylinder as a backup to his SA. Was hoping he would post up some running cost numbers as a back to back comparison.
JohnMo Posted March 8, 2025 Posted March 8, 2025 28 minutes ago, DamonHD said: am using a Thermino *alongside* my heat pump DHW tank, and I don't expect to be paying to import much electricity between now and September I'm just using a cylinder and again don't expect to say much if anything, without the additional Thermino. Used excess PV today and then immersion took it up to 65 degs.
Stanchev Posted November 6, 2025 Posted November 6, 2025 On 08/03/2025 at 09:45, Diarmid said: Looking to replace lpg heating system (underfloor heating) with ASHP combo. House is end terraced cottage about 120m2. Insulation 150mm PIR all round and triple glazed. Had a couple of quotes and one interests me in particular. ASHP + Thermino xPlus + 5kw battery + solar array, the rep mentioned a COP of 4.0 and expressed confidence in this, which surprised me? I thought COP of such systems were compromised by the need to run high water temperatures back to the 'tank' Grateful for opinions... ASHP with solar and battery would be great for you. Get as larger storage battery as you can with min 6-10 solar panels if you have space. If you manage to get a cheap night tariff of say 7p per 1kW and if you have 15 or better 20kW battery you can run the ASHP without getting from the grid. Between April and October you can export excess power at the end of the day at say 15p per 1kW. From November till March your solar will produce very little. I have 12 solar panels with 5.36kW combine power and on a cloudy day I get around 3 to 5 kW production a day and if I have not had a 10kWh storage battery, I would needed to use the grid. Now I only use the grid to charge the battery between 23:30-05:30 at 7p per 1kW and 99% of the time no more consumption of the grid during the day. In the ever so hot Summers now in the UK you will be pleased to use the ASHP to cool the house and sleep properly without extra expense, because there is plenty of sunshine and your solar will produce a lot of energy. Choose a good tariff which pays for export and it is cheap to charge the storage battery. I am with Octopus Go because I have an EV. If you can get something like that, would be great. In summary, get as larger storage battery as you can, even with less solar panels than planned. All the best.
