Mulberry View Posted March 6, 2025 Posted March 6, 2025 I'm hoping to start digging my 20m3 Soakaway this weekend. I'm going for 6m x 3.6m x 0.84m. 1. Pea Shingle or Sharp Sand to surround the crates? 2. Geotextile wrap for the crates yes, but should I also provide another separation layer between the backfill layer and the surrounding soil? I'm grateful for you guys, so any help here is appreciated as always.
Mulberry View Posted March 6, 2025 Author Posted March 6, 2025 3 minutes ago, JohnMo said: If using crates follow manufacturer instructions? I don't have the crates yet, I didn't realise they'll supply this?!
JohnMo Posted March 6, 2025 Posted March 6, 2025 https://www.cotterillcivils.co.uk/blogs/guides-to-flood-management/how-to-install-soakaway-crates?srsltid=AfmBOoohgOP6ReHBhn3MNaLCNlKWv0QntWy-0RO-CJBHyVViWn_e6_77 We didn't use crates at all, just slotted 110mm pipe in crushed gravel, geotextile below and above. The pipes were covered with more gravel then geotextile. 1
Mulberry View Posted March 6, 2025 Author Posted March 6, 2025 5 minutes ago, JohnMo said: https://www.cotterillcivils.co.uk/blogs/guides-to-flood-management/how-to-install-soakaway-crates?srsltid=AfmBOoohgOP6ReHBhn3MNaLCNlKWv0QntWy-0RO-CJBHyVViWn_e6_77 We didn't use crates at all, just slotted 110mm pipe in crushed gravel, geotextile below and above. The pipes were covered with more gravel then geotextile. That's quite cool. Is it an alternative to a crated soakaway or something completely different?
JohnMo Posted March 6, 2025 Posted March 6, 2025 1 minute ago, Mulberry View said: That's quite cool. Is it an alternative to a crated soakaway or something completely different? Crates are really an alternative to what we did. That design just follows the recommended design by SEPA. If you have space its easy and almost no material costs.
BotusBuild Posted March 6, 2025 Posted March 6, 2025 8 hours ago, JohnMo said: We didn't use crates at all, just slotted 110mm pipe in crushed gravel, geotextile below and above. Just what we did for our sewage treatment plant
