Pocster Posted January 29, 2025 Posted January 29, 2025 (edited) Rental . Smoke alarms are interlinked and have no control panel . Honeywell control panel is just for the 4 call points ( still want to call them break glass ) . Randomly it will show a fault on one . Panel beeps to alert you . Enter code , cancel beep , then reset panel and ‘fault’ disappears There are only 3 components here ; panel , all the call points , the wiring . I’ve been told a ‘load resistor’ can be put across the call points to prevent it showing a fault . The supposed call point that fails appears to be random also . This resistor doesn’t sound particularly appealing to me . This ok though ? . Panel can go weeks or even months with no issues . My only other solution was new panel and call points . Then if still errors must be the wiring . Edited January 29, 2025 by Pocster
dpmiller Posted January 30, 2025 Posted January 30, 2025 are the call points a normaly open/ closed switch, or instead some kind of addressed device?
Pocster Posted January 30, 2025 Author Posted January 30, 2025 1 hour ago, dpmiller said: are the call points a normaly open/ closed switch, or instead some kind of addressed device? Not sure . Would assume just normally opened or closed . No complexity of an addressed device .
dpmiller Posted January 30, 2025 Posted January 30, 2025 6 hours ago, Pocster said: Not sure . Would assume just normally opened or closed . No complexity of an addressed device . well if they're just normally_open, a resistor might be used to control any stray voltages that could be induced in the wiring 1
Pocster Posted January 30, 2025 Author Posted January 30, 2025 44 minutes ago, dpmiller said: well if they're just normally_open, a resistor might be used to control any stray voltages that could be induced in the wiring Yes . But I was informed by another that if a real fault occurred on the call point it would never register as a fault on the panel . ; if resistor installed . Tenant pushes call point , nothing happens , tenant burns to death etc etc … 🫤
Pocster Posted January 30, 2025 Author Posted January 30, 2025 17 minutes ago, dpmiller said: would depend on the resistor. Isn’t that tricky though ? . Intermittent fault , resistor enough to stop fake fault but ok with real fault ? 🫤 Just sounds a bit bodgey ; as you know that ain’t my style 🙄🫤🙄
sharpener Posted January 31, 2025 Posted January 31, 2025 (edited) 21 hours ago, Pocster said: Isn’t that tricky though ? . Intermittent fault , resistor enough to stop fake fault but ok with real fault ? 🫤 Just sounds a bit bodgey ; as you know that ain’t my style 🙄🫤🙄 Leakage or induced pickup from other wiring is a real possibility depending on what the input circuit impedance on the panel is. Might have a pull-up resistor and a proper voltage comparator. Or might just be a CMOS input pin. If product is well-designed it will have some RC network and/or Schmitt trigger input to make it noise proof - ah I see you mention Honeywell so all bets are off. So determine by experiment what value resistor would be recognised as a contact closure i.e. triggers alarm. Then fit resistor 10x this value. Unlikely to fail to danger, in a real "break glass" situation it would be shorted by the switch contacts anyway. OTOH if the switch opens on break glass then I can't see the resistor doing anything at all. This is potentially a better method as it constantly tests the wiring continuity. And a loose terminal screw would cause an intermittent false alarm. So you need to find out which way round it works. Edited January 31, 2025 by sharpener 1
Pocster Posted January 31, 2025 Author Posted January 31, 2025 5 minutes ago, sharpener said: So you need to find out which way round it works. No idea . Being dicked around by fire alarm company who want £165+vat to look at it . As the fault won’t be present then that’s pointless . But do have another company coming Monday to look for free … so I’ll see what he says , I’ll ask open / closed circuit on call points .
sharpener Posted January 31, 2025 Posted January 31, 2025 When all else fails an old-fashioned analogue multimeter is your friend. 1
Alan Ambrose Posted February 1, 2025 Posted February 1, 2025 Has it always done this, or is this a new thing? Suggest checking the obvious things first - backup battery, tightness of all connections at panel and at all call points. Also scouring the fire alarm forums … assuming those kind of forums exist. If it’s been doing this from the start it may be a Honeywell design issue. Easiest thing probably is to get the lot replaced - probably not v expensive. Yeah, you could try and do a proper diagnosis, but intermittent faults are notoriously hard. Also, while personally I’ll try to do anything and everything as DIY - making a modification to a fire system, in a rental, even if the manufacturer has screwed up the design, is probably something even I wouldn’t do . 1
Pocster Posted February 1, 2025 Author Posted February 1, 2025 (edited) 4 hours ago, Alan Ambrose said: Has it always done this, or is this a new thing? Suggest checking the obvious things first - backup battery, tightness of all connections at panel and at all call points. Also scouring the fire alarm forums … assuming those kind of forums exist. If it’s been doing this from the start it may be a Honeywell design issue. Easiest thing probably is to get the lot replaced - probably not v expensive. Yeah, you could try and do a proper diagnosis, but intermittent faults are notoriously hard. Also, while personally I’ll try to do anything and everything as DIY - making a modification to a fire system, in a rental, even if the manufacturer has screwed up the design, is probably something even I wouldn’t do . It was fine for a few years and then random faults started to appear . Electricians etc have all looked at it even with the fault ( light ! ) present . Nothing ever found . I agree ; as a rental I’m not going to touch this … Probably get panel and call points all replaced first . Another guy looking Monday foc … Edited February 1, 2025 by Pocster
