Co1 Posted January 20 Posted January 20 (edited) Hi there I have a planning application in at the moment for a 2m x 2m front porch and a 4m x 4m rear extension. Both are single story, on my single story bungalow. Both timber clad with pitched roofs abutting the main roof. Nothing fancy! Does just shy of £950 seem reasonable? Are there other ways to do it, or am I beholden to my local inspector? Thanks Col Edited January 20 by Co1
Redbeard Posted January 20 Posted January 20 Hello! Your thread title refers to Building Regs and you refer in the OP to Planning. The OP seems to suggest that £950 is for planning only. Can you disconfuse me?
Co1 Posted January 20 Author Posted January 20 Sorry, to be clear the price I’ve received is for building control.
Redbeard Posted January 20 Posted January 20 (edited) https://buildingcontrol.bathnes.gov.uk/building-control-services/building-control-fees-and-charges This isn't Yorkshire, of course, but does it shed some light? While searching I see a sugg'n from one firm that private BC can be cheaper but I am not sure that is always the case. Edit: Indeed it isn't: The search brought up only the application fee, not the inspection fee. I have sometimes had a discount from my LA on the 2nd app when I have done 2 together. Your price suggests maybe this has been applied. Assuming they are charging a fee for each extension, rather than one for both, I think your price sounds about right. Edited January 20 by Redbeard 1
DevilDamo Posted January 20 Posted January 20 Does the porch actually require BR’s? If so, will you be carrying out the porch and extension at the same time?
Co1 Posted January 20 Author Posted January 20 Thanks a lot. Am I right in not paying this until planning is granted, on the basis that planning might be refused and I will have wasted the cash?
nod Posted January 20 Posted January 20 On 20/01/2025 at 20:58, Co1 said: Thanks a lot. Am I right in not paying this until planning is granted, on the basis that planning might be refused and I will have wasted the cash? Expand You don’t pay for building control till all the planning and materials are agreed We paid around £850 for a full house and workshop I think LA have a standard price for there services 1
Co1 Posted January 21 Author Posted January 21 On 20/01/2025 at 20:58, DevilDamo said: Does the porch actually require BR’s? If so, will you be carrying out the porch and extension at the same time? Expand According to the planning portal it does. There will be a bit of a delay between them, porch is in May, rear extension is in August.
DevilDamo Posted January 21 Posted January 21 On 21/01/2025 at 06:48, Co1 said: According to the planning portal it does. There will be a bit of a delay between them, porch is in May, rear extension is in August. Expand Assume you’ll be removing or replacing the original front door then because if so, it’ll be a single storey front extension. As you’ll be carrying out the works in stages, they have calculated the fees as separate projects. If you were to carry them out at the same time, then they would only need to carry out one set of inspections. 1
Co1 Posted January 22 Author Posted January 22 The original front door will stay in place as an inner door. There will be a new door on the front of the porch facing the roadside.
DevilDamo Posted January 22 Posted January 22 On 22/01/2025 at 06:46, Co1 said: The original front door will stay in place as an inner door. There will be a new door on the front of the porch facing the roadside. Expand Ok and which is why BR’s are required as you’re pushing out the thermal envelope. 1
kandgmitchell Posted January 22 Posted January 22 If it's a porch erected over a retained door and is less than 30m2 floor area then it's a Class 7 exempt building (note the need for the glazing to comply with safety requirements).
Gordo Posted January 22 Posted January 22 (edited) On 22/01/2025 at 17:11, kandgmitchell said: exempt building Expand Do exempt buildings not have to be detached? The fees for extensions are based on the combined overall extension area. They are not separate fees for each extension Edited January 22 by Gordo 1
kandgmitchell Posted January 23 Posted January 23 Nope: Schedule 2 of the Building Regulations...... CLASS 7 Extensions The extension of a building by the addition at ground level of— (a)a conservatory, porch, covered yard or covered way; or (b)a carport open on at least two sides; where the floor area of that extension does not exceed 30m2, provided that in the case of a conservatory or porch which is wholly or partly glazed, the glazing satisfies the requirements of F3[F4Part K4, K5.1, K5.2, K5.3, and K5.4] [F3Part N] of Schedule 1.
Gordo Posted January 24 Posted January 24 On 23/01/2025 at 10:25, kandgmitchell said: CLASS 7 Extensions Expand Oh yes forgot about that
