Co1 Posted Monday at 19:42 Share Posted Monday at 19:42 (edited) Hi there I have a planning application in at the moment for a 2m x 2m front porch and a 4m x 4m rear extension. Both are single story, on my single story bungalow. Both timber clad with pitched roofs abutting the main roof. Nothing fancy! Does just shy of £950 seem reasonable? Are there other ways to do it, or am I beholden to my local inspector? Thanks Col Edited Monday at 19:58 by Co1 Link to comment Share on other sites More sharing options...
Redbeard Posted Monday at 20:35 Share Posted Monday at 20:35 Hello! Your thread title refers to Building Regs and you refer in the OP to Planning. The OP seems to suggest that £950 is for planning only. Can you disconfuse me? Link to comment Share on other sites More sharing options...
Co1 Posted Monday at 20:38 Author Share Posted Monday at 20:38 Sorry, to be clear the price I’ve received is for building control. Link to comment Share on other sites More sharing options...
Redbeard Posted Monday at 20:43 Share Posted Monday at 20:43 (edited) https://buildingcontrol.bathnes.gov.uk/building-control-services/building-control-fees-and-charges This isn't Yorkshire, of course, but does it shed some light? While searching I see a sugg'n from one firm that private BC can be cheaper but I am not sure that is always the case. Edit: Indeed it isn't: The search brought up only the application fee, not the inspection fee. I have sometimes had a discount from my LA on the 2nd app when I have done 2 together. Your price suggests maybe this has been applied. Assuming they are charging a fee for each extension, rather than one for both, I think your price sounds about right. Edited Monday at 20:51 by Redbeard 1 Link to comment Share on other sites More sharing options...
DevilDamo Posted Monday at 20:58 Share Posted Monday at 20:58 Does the porch actually require BR’s? If so, will you be carrying out the porch and extension at the same time? Link to comment Share on other sites More sharing options...
Co1 Posted Monday at 20:58 Author Share Posted Monday at 20:58 Thanks a lot. Am I right in not paying this until planning is granted, on the basis that planning might be refused and I will have wasted the cash? Link to comment Share on other sites More sharing options...
nod Posted Monday at 21:10 Share Posted Monday at 21:10 9 minutes ago, Co1 said: Thanks a lot. Am I right in not paying this until planning is granted, on the basis that planning might be refused and I will have wasted the cash? You don’t pay for building control till all the planning and materials are agreed We paid around £850 for a full house and workshop I think LA have a standard price for there services 1 Link to comment Share on other sites More sharing options...
Co1 Posted 17 hours ago Author Share Posted 17 hours ago Thanks Nod, much appreciated. Link to comment Share on other sites More sharing options...
Co1 Posted 17 hours ago Author Share Posted 17 hours ago 9 hours ago, DevilDamo said: Does the porch actually require BR’s? If so, will you be carrying out the porch and extension at the same time? According to the planning portal it does. There will be a bit of a delay between them, porch is in May, rear extension is in August. Link to comment Share on other sites More sharing options...
DevilDamo Posted 16 hours ago Share Posted 16 hours ago 1 hour ago, Co1 said: According to the planning portal it does. There will be a bit of a delay between them, porch is in May, rear extension is in August. Assume you’ll be removing or replacing the original front door then because if so, it’ll be a single storey front extension. As you’ll be carrying out the works in stages, they have calculated the fees as separate projects. If you were to carry them out at the same time, then they would only need to carry out one set of inspections. Link to comment Share on other sites More sharing options...
