BadgerBadger Posted 22 hours ago Share Posted 22 hours ago Hi all - we're about to install acoustic insulation in our 400mm centres posi joist floor. But I'm not sure what the best size/product to get. I can get Rockwool RWA45 but only in 600mm wide slabs, is this going to be really wasteful/awkward on 400 centres? Can a stuff two offcuts next to each other and they'll hold in place, or should I be cutting the slab widthways and laying smaller pieces. Alternatively I can get Rockwool Flexi in 400mm wide slabs, are these going to be easier? As ever in this self-building game I'm pretty sure I could work this out by trying for a couple of hours, but by that point I'd have ordered a pallet of the wrong material! 🤣 Link to comment Share on other sites More sharing options...
crispy_wafer Posted 21 hours ago Share Posted 21 hours ago We used APR in the ceilings along with res bar, saved the RWA for the walls. RWA in the ceilings would have been a ballache... RWA is fairly rigid so offcuts will hold when pressed against each other, however once you get a row in place I'd recommend you be careful if you try to adjust it's positioning as it'll all move! Link to comment Share on other sites More sharing options...
nod Posted 17 hours ago Share Posted 17 hours ago Use ISO roll Cut it into three with a sharp hand saw 400 mil rolls before taking the plastic off Link to comment Share on other sites More sharing options...
