We’re gathering quotes for (mostly) aluclad timber windows and there’s (predictably) a very broad range of prices. The two systems we like most are over £30k more expensive than our third choice, but have 2 or 3 seals instead of just 1 in the cheaper system. They all have comparable Uw values and perfectly acceptable aesthetics. The more expensive systems feel more substantial in operation, but a lot of the windows are fixed and most of the openers will probably be rarely opened. So I’m wondering how important are the multiple seals? £30k buys an awful lot of other stuff….
It it worth getting the cheaper ones for fixed and more expensive for opening?  There is no rule that says they all need to be from the same manufacturer.  Get them both to send a RAL sample before you commit.
That’s probably quite feasible. I can see us using different companies for windows & sliders anyway. The openers are mostly first floor, with ground floor being fixed, sliders or patio doors, so slightly different aesthetics probably wouldn’t be too noticeable.
I wonder whether @craig has any thoughts? Also how you tell a good window from a bad one?
We were at the Farnborough housebuilding show yesterday and looked at windows from Internorm and Norsken. I remember Internorm being on Craig’s good list, but actually we preferred the look of the Norsken ones.
The question we had in our minds was ‘what makes the Internorm ones better’? Something with the mechanism or seals or insulation?
We're getting a quote from Craig :) 👍
Internorm & Norrsken are probably our two top contenders at the moment, but they're pricey. I think the Internorm seals seem 'better' than Norrsken, insofar as there are more of them, but we'd ideally prefer outward opening which Internorm don't do. Nordan is currently number three, but is notably cheaper. Some of our fixed windows are quite large and a few manufacturers can't do them in one piece. For aesthetic reasons, we also really want our main lift & slide to be three panel but a few of the suppliers can only do two or four, or a two with a fixed side panel which doesn't look right.
This really is proving quite tricky! :)
Fantastic. Hope we're doing well. Don't be scared to tell us where we are and if there is something we need to do etc. Always ask, generally there things we can do, sometimes it's a case of sorry.
You should be able to get a Scheme B which from memory is lift and slide centre, one fixed either side in timber aluminium. A double track system is usually offered system designer (Siegenia, Maco, GU etc.) however most manufacturers do not offer it. It is available in aluminium only, check if that's an option.
That is a fantastic question @Alan Ambrose and one I would really like to answer in depth at some point but a basic answer is this. Those at the higher end of the price point are at that price point for a reason, those at the lowest end / middle are also there for a reason. However, triple gaskets can supply a better weather tightness results v's one gasket. Outward opening with one single gasket might have a similar or better result based on the nature of how the pressure is applied.
