markharro Posted yesterday at 17:10 Share Posted yesterday at 17:10 My other half is seemingly changing her mind about a shower niche after she was adamant she didn't want one!! Annoyingly the studs have backer board on with screw heads and joints sealed etc and in fact one board that part cover a possible niche location is now impossible to remove. I could easily multitool an opening having said all this but what is needed after that? Can I build out the internal frame needed through a window cut in the backer board? thanks Link to comment Share on other sites More sharing options...
BotusBuild Posted yesterday at 18:41 Share Posted yesterday at 18:41 Open the window for the niche. Measure and cut four pieces of stud timber (same width & depth as already used in that wall) Pop each short stud through the window and screw hold with screws through the backer board. TIP: put a screw in each short stud to hold onto while putting the final screws in. Ask the other half for help on this seeing as they changed their mind!! 🙂 Put backer board in to create final niche size. HTH Link to comment Share on other sites More sharing options...
Onoff Posted yesterday at 19:08 Share Posted yesterday at 19:08 No probs at all cutting out for a niche. Consider your niche vs tile size carefully so as to end on a grout line, consider how the trims will sit etc. Oh, and use a tile spacing / levelling system, wish I had 😡 Link to comment Share on other sites More sharing options...
Andehh Posted 22 hours ago Share Posted 22 hours ago They are very prone to leak, so consider a decent slope for water run off and seal it all very thoroughly! Link to comment Share on other sites More sharing options...
