markharro Posted January 14, 2025 Posted January 14, 2025 My other half is seemingly changing her mind about a shower niche after she was adamant she didn't want one!! Annoyingly the studs have backer board on with screw heads and joints sealed etc and in fact one board that part cover a possible niche location is now impossible to remove. I could easily multitool an opening having said all this but what is needed after that? Can I build out the internal frame needed through a window cut in the backer board? thanks
BotusBuild Posted January 14, 2025 Posted January 14, 2025 Open the window for the niche. Measure and cut four pieces of stud timber (same width & depth as already used in that wall) Pop each short stud through the window and screw hold with screws through the backer board. TIP: put a screw in each short stud to hold onto while putting the final screws in. Ask the other half for help on this seeing as they changed their mind!! 🙂 Put backer board in to create final niche size. HTH
Onoff Posted January 14, 2025 Posted January 14, 2025 No probs at all cutting out for a niche. Consider your niche vs tile size carefully so as to end on a grout line, consider how the trims will sit etc. Oh, and use a tile spacing / levelling system, wish I had 😡
Andeh Posted January 14, 2025 Posted January 14, 2025 They are very prone to leak, so consider a decent slope for water run off and seal it all very thoroughly!
