Been looking at ways to reduce bridging on studs and wondered if anyone has tried this.  89mmx38mm studs with 12mm Jackoboard (insulated tile backer board) shims over studs and 100mm insulation between. I'm figuring that Jackoboard's insulation will break the bridge (to an extent) and since it can take screws and hold tiles etc, it will be plenty strong enough for plasterboard.
A 1200x600 board costs around £10 and can make 15 shims so its not too much of an add on cost.
Image gives an idea of what I'm thinking.
Hello. I think we need to know more about 'where these studs are' before we can comment much. What is on the other side? The outside world? Another heated room? An unheated room?
You mention 'bridging' but not 'thermal bridging'. Is sound-proofing more the issue than 'thermals'?
More details, please!
Apologies - thermal bridge. Heated room, Stud wall, 70-100mm air gap to 600mm granite and rubble external wall. As per image
I see where you're coming from but the strips can't be even slightly wide or they'll compromise tightly fitting the PIR which is difficult enough anyway. Then if they're a bit narrow any gaps will mean they're not doing much.
Thermally, 75mm between then 25mm insulated plasterboard over would better reduce bridging and also mitigate any gaps where you've not fitted the PIR tightly between studs.
If you do go the strips route I see there's a Jackodur board that's rigid XPS without the tilable face (that you don't need)
One of the insulation manufacturers (can’t remember which one) introduced a similar system, just with xps strips, quite few years ago. Was not a success and soon dropped!
I would
Make the infill insulation thinner, so flush with stud. Then over sheet whole wall in a layer of PIR insulation and the plasterboard.
You need to consider services (wires plumbing etc) what are doing with these?
Can you loose more room space? If so replace between studs with dense mineral wool and 50mm PIR over studs.
It was Knauf, IIRC, and in fact the principle has, I believe, been 're-born' in SWIPS, which I have not seen, but I understand is an IWI system using 'insulated studs'. It is apparently used quite a lot in ECO4 -funded schemes.
