Afternoon!
So I have a metal front house (sitex) door that I want to paint. Only want to paint the front of it. Only plan to sand it then paint it once
Would one small 250ml can of Hammerite paint be enough? I mean I dont want to end up with pain in storage that will go off in 10 years time next time I need it
Thanks
PS are there cheaper metal paints out there apart from Hammerite
I asked my neighbour the same question as we have the same sized doors.
He said 1.5 litres.
I went and got 1.5 litres and painted the door, had over a litre left.
When I said to him about the amount left over, he said 'yes, same amount as me'
  • Haha 3
Several options for metal paint, depends on what the surface is like now. Hammerstein is good if you don’t need a good finish or to do any/much prep.
if you are going to put a bit of effort in then flat, etch primer and then rattle can or brushing enamel (all available from vehicle paint places).
He said 1.5 litres.
In other words he/she is a complete and utter.............
BTW was it a metal or wooden door?
Not bad, I mean no rust, just faded brown paint (with grathete) that dose not look nice
Im using my mini grinder to clean it up. Any recommendations on a paint for good finish (black)
From memory the lads with the body shops round hear use 3 pains. A primer, lacker, and something for finishing (cant rememer now)
Since as there is no rust though and paintwork is ok; do I need a primer?
Hi @lord mud of the flyes better to always use a primer to improve adhesion to the surface wether it’s bare or paint, aerosol etch primer is good stuff.
body shops often have primer/base coat/laquer - mainly due to metallics which really need a clear coat over the top.
black is a solid colour so no laquer/clear coat needed. Most areas have a place for car painting supplies and these are your best bet for the paint.
