Gringo Posted December 25, 2024 Share Posted December 25, 2024 Having moved to our bungalow around 3 years ago, I'm having to replace our ensuite shower tray due to damp issues. I decided to gut the whole room & start again & I've dug up most of the subfloor under the tray & found that the idiot who installed it 10 years ago just cut through & dug up the original DMP & didn't replace it with anything! This left the whole area under the tray exposed to damp ingress from the subsoil & moisture creeping through under the DPC in the external wall, the internal wall above the DPC was also extremely damp. This is obviously what was causing the smell & things going rusty which first made me aware there was obviously a problem. I've dug up most of the subfloor under the tray to let it dry out & will be reinstating a new DPM, connecting this to the wall external DPC before installing new drainage & a new stone resin tray. I've done this before a couple of times in the distant past but found bedding on a weak mix concrete, as per most tray manufacturers standard instructions, less than ideal TBH. I'm generally experienced in all aspects of building work including dry lining, plastering & tiling etc. & wondered if anyone can offer opinions/experience on bedding the new tray on either drywall adhesive or a waterproof tile adhesive as an alternative. Link to comment Share on other sites More sharing options...
Iceverge Posted December 25, 2024 Share Posted December 25, 2024 We have a slate effect tray and I don't like it. I much prefer a plain white one. Far easier to clean. Our plumbers put them on sand/cement and as it turned out some gravel too. Made a complete balls of it, bouncy and hollow. Next time I would use a Mira tray (bedded on Tile adhesive) with upstands or else make a wet room style floor. 1 Link to comment Share on other sites More sharing options...
Kelvin Posted December 25, 2024 Share Posted December 25, 2024 The shower try makers normally have instructions on how they want their trays installed. One of ours was on flexible tile adhesive and the other expanding foam. The main thing is a strong level base. 1 Link to comment Share on other sites More sharing options...
nod Posted December 25, 2024 Share Posted December 25, 2024 Flexi tile adhesive works well I agree with Ice about the skate effect I put them in our last build Looked great Rubbish to keep clean Back to white this time 1 Link to comment Share on other sites More sharing options...
Kelvin Posted December 25, 2024 Share Posted December 25, 2024 One of ours is a grey blue colour and hard to keep clean. The other is white and much better. Link to comment Share on other sites More sharing options...
FarmerN Posted December 26, 2024 Share Posted December 26, 2024 Like our White Stone resin tray. Level access. Use a long handled scrubbing brush for a once a month clean up, soon scrubs up like new. Link to comment Share on other sites More sharing options...
Gringo Posted December 26, 2024 Author Share Posted December 26, 2024 Unfortunately it's a black, slate effect tray which "she who must be obeyed" picked. All manufacturer's generally recommend a weak concrete mix bed & have done for the last 20 years or so but, as I said, I've found this less than ideal. I'm thinking that, with the modern building materials now available, there must be a better option. I thought about using expanding foam but wondered if it was strong enough to carry the weight of our new, 120cm x 80cm stone resin tray tray which weighs in at about 30kg! After all the problems I've had with the last "tradesman's" efforts on DPM & plumbing, the very last I want is to have to pull it all up again! Link to comment Share on other sites More sharing options...
Kelvin Posted December 26, 2024 Share Posted December 26, 2024 Ours is slightly bigger than 120cm x 80cm (was cut to fit) and it’s fixed with low expansion PU foam as per the instructions. I was rather sceptical but seems to be fine so far. 1 Link to comment Share on other sites More sharing options...
Iceverge Posted December 27, 2024 Share Posted December 27, 2024 How about squirting several tubes of silicone in there? 1 Link to comment Share on other sites More sharing options...
Gringo Posted December 27, 2024 Author Share Posted December 27, 2024 13 hours ago, Kelvin said: Ours is slightly bigger than 120cm x 80cm (was cut to fit) and it’s fixed with low expansion PU foam as per the instructions. I was rather sceptical but seems to be fine so far. Was that a stone resin tray or fibre glass? Stone resin is much heavier compared to FG. Link to comment Share on other sites More sharing options...
Gringo Posted December 27, 2024 Author Share Posted December 27, 2024 8 hours ago, Iceverge said: How about squirting several tubes of silicone in there? Silone would stick it down OK but wouldn't be very effective to allow levelling. Stone resin tray's must also fully supported underneath or they will crack. Link to comment Share on other sites More sharing options...
Kelvin Posted December 27, 2024 Share Posted December 27, 2024 (edited) 1 hour ago, Gringo said: Was that a stone resin tray or fibre glass? Stone resin is much heavier compared to FG. Stone resin. Here’s the install instructions Edited December 27, 2024 by Kelvin 1 Link to comment Share on other sites More sharing options...
Gringo Posted December 27, 2024 Author Share Posted December 27, 2024 1 hour ago, Kelvin said: Stone resin. Here’s the install instructions Many thanks. Link to comment Share on other sites More sharing options...
