Hi,
I'm planning to use EWIPro 225, 333 and 076 on our eps blocks.
I just wondered whether it's necessary to rasp and or wash the blocks first, and whether we should use 310 primer first under the 225.
The blocks are about 6 months old, so not dusty yet.
Thanks for reading.
I don't know the product you are using but any that I have used all requiring rasping
The block maybe clean but its also got too smooth a surface so the base coat will not adhere and be loose and potentially fall off
And even tho only 6 months old I can assure you there is some UV damage and a light film on it, rub your hand across it and you will see it on your hand but maybe not visible to see
Edited by ChrisJ
