Dee J Posted November 21, 2017 Share Posted November 21, 2017 The perils of lunchtime daytime tv. Looking at the build method of a bungalow shown partly completed on TV. Newbuild solid single skin blockwork structure due to be externally insulated and rendered - but it didn't look like passive slab base. From visible details it looked like strip foundation with a conventional screeded floor ( might have been slab or beam and block under). By the look of it there are a couple of courses of a different blockwork at the ground transition - some sort of thermal blockwork maybe to offset heat loss at foundation. Standard thermalite? or is there some wonder-product block with better characteristics? Link to comment Share on other sites More sharing options...
Ian Posted November 21, 2017 Share Posted November 21, 2017 5 minutes ago, Dee J said: or is there some wonder-product block with better characteristics? This kind of product maybe?: http://www.marmox.co.uk/products/thermoblock Link to comment Share on other sites More sharing options...
Dee J Posted November 21, 2017 Author Share Posted November 21, 2017 3 minutes ago, Ian said: This kind of product maybe?: http://www.marmox.co.uk/products/thermoblock That would fit the bill, but by the look of the TV example it looked to be standard block-on-its-side sizing rather than the longer Marmox format. I'll keep Marmox in mind for our project though... Link to comment Share on other sites More sharing options...
Ian Posted November 21, 2017 Share Posted November 21, 2017 18 minutes ago, Dee J said: I'll keep Marmox in mind for our project though... They are expensive and so there will almost certainly be a cheaper method of achieving the same end result using other products. Link to comment Share on other sites More sharing options...
