UFH/screed question
This may be suited more the the flooring section of forum but I wasn’t sure.
We are having UFH in our new build on the ground floor and obviously a screed will need to be poured over that. My question is, is there a type of screed that can be used that can then be polished and act as the main floor? If so, is this significantly more expensive as an option (obviously the saving of not using another flooring can offset this)?
