Evening all,
Just 1st fixing electrics - moved onto bathrooms & for these I've got some of these:
https://www.wundatrade.co.uk/shop/home/accessories/electrics-2/touchscreen-thermostat-combo/
The supplied probe is 3m long - is it possible to extend these?  If so, what impact would it have on the readings?
If its not possible to extend then then I need to rethink the location of the thermostat - which I'd rather not do.
Any help / advice gratefully received.
Thanks
Extending them is no problem at all, been done plenty of times :). Make the joint above ground and if possible accesble, if not, I'd recommend soldering and heat shrink sleeving to get a lifetime hassle free joint.
Measure the resistance before and after the connection and you'll know it's been done properly.
Thanks Nick - after many years doing rc buggy's soldering should not be a prob - what wire would you use to extend them with?  Does extending them alter their accuracy? Increase time lag?
No issues whatsoever mate ;)
I race Caster 1/10th scale with my boys when indoors, and they've got FTX Colossus's 1/8th for rally cross / bashing. All running lipos with brushless. My summer goal is to get my Losi 2.0 rolling chassis converted to electric and running, proper old school one which I'll be running 22v ?
Got a few tbh.  Current fav is a carisma gtb - indoors on carpet its fantastic.  Next summer will get the balance between house and racing sorted and brush off the b44.  You've got some big boys toys there, those 1/8ths must go like stink....  Thank god for lipo's.
Anyway back on topic - any suggestions regarding wire to extend the sensor? ??
0.5mm 2-core flex ought to do it nicely, or whatever you have. Cat 5 even. The resistance of the NTC sensor will be massive compared to whatever you use and there's practically no current flowing...
The micros make me dizzy. Too small and too bloody quick :D
Looking for another Lunchbox rolling chassis for daughter #2 now.
Fast and furious are also cheap on repairs and good for small venues.  Way to go!
Thanks to all for the help on the thermostat query
