Sand Cement over Chasings Sufficient for Airtightness
Gaf
Wasn't sure to post here or in ventilation - my main concern with airtightness is the heat retention as we have MVHR looking after the ventilation (as least that's my understanding!).
Builder said that after the chasings are serviced (e.g. electrician does his thing), he uses a sand cement mix to fill in the chasings for airtightness. He doesn't use airtightness paint (e.g. blowerproof).
I'd seen posts here stating that sand-cement internal skimming is a perfectly good airtightness layer, so would there be any drawbacks to the builder's proposed method for the chasings?
