Gaf Posted November 22, 2024 Posted November 22, 2024 Wasn't sure to post here or in ventilation - my main concern with airtightness is the heat retention as we have MVHR looking after the ventilation (as least that's my understanding!). Builder said that after the chasings are serviced (e.g. electrician does his thing), he uses a sand cement mix to fill in the chasings for airtightness. He doesn't use airtightness paint (e.g. blowerproof). I'd seen posts here stating that sand-cement internal skimming is a perfectly good airtightness layer, so would there be any drawbacks to the builder's proposed method for the chasings?
Russell griffiths Posted November 22, 2024 Posted November 22, 2024 What is your airtight strategy, wet plaster, dot n dab boards, airtight membrane over the walls. as long as what he does ties in with the rest of your airtight strategy and doesn’t hinder it then that’s fine.
Gaf Posted December 26, 2024 Author Posted December 26, 2024 On 22/11/2024 at 15:07, Russell griffiths said: What is your airtight strategy, wet plaster, dot n dab boards, airtight membrane over the walls. as long as what he does ties in with the rest of your airtight strategy and doesn’t hinder it then that’s fine. Apologies only coming back to this now. The overall strategies used are: - Ceiling-wall joints taped - Wall-window joints taped - Sand cement coating on all inner leaf walls - Some kind of passive house memberane attached across the whole roof-ceiling area, stuck/taped to the ceiling-walls joint tape
