OldieNewbie Posted November 20, 2024 Posted November 20, 2024 Hi all, my friend built a kind of lean to using timber and roofed it with perspex during lockdown. He didn’t lap the sheets of perspex and butted them up to each other, and sealed with silicone. It has started to leak. can perspex sheets be welded together to create a seal? Would this be cost effective? thanks
JohnMo Posted November 20, 2024 Posted November 20, 2024 10 minutes ago, OldieNewbie said: can perspex sheets be welded together to create a seal You should be able to weld, but it is likely to look awful. No idea how you would go about it. Would be better to look a some butt joint seals.
Andehh Posted December 1, 2024 Posted December 1, 2024 Wait until a dry day, masking tape and a generous bead of silicone along the joint? It's only a lean to...
Alan Ambrose Posted December 1, 2024 Posted December 1, 2024 Did he get some 2nd material cheap? Otherwise it was probably polycarb. If really perspex / acrylic, then look up instructions for making fish tanks. If polycarb, maybe there’s some kind of rubber / plastic beading that can be glued over the joints. Else +1 to silicone.
