Duncan62 Posted October 22, 2024 Posted October 22, 2024 Or very good carpenters are saying I should have 2 methane layers on the roof. First as a house wrap. Second draping between a counter batten, before the battens and tiles installed. Build up is: Insulation filled rafters External 60mm wood fibre insulation House wrap membrane Counter batten *Secondary membrane layer* Batten Tiles. Is this standard practice on a warm fit design? My thinking was a single membrane layer against the wood fibre?
JohnMo Posted October 23, 2024 Posted October 23, 2024 15 hours ago, Duncan62 said: should have 2 methane layers on the roof Methane? What do your drawings state? Is you house wrap certified for roofing applications? Suspect the joiners are wrong. 1
Duncan62 Posted October 23, 2024 Author Posted October 23, 2024 That should be membrane. Yes certified: Rothoblaas Transpair Evo 160. I did the drawings. Roofer said single membrane. Will add butyl tape under each counter batten too. Belt and braces. Hopefully this sounds sensible?
Iceverge Posted October 23, 2024 Posted October 23, 2024 Woodfiber boards don't need any membrane in some applications so the carpenters are over killing a little. Their understanding may be based on some older membrane types which demanded a ventilated layer at both sides as the weren't of sufficiently low Sd value. But for me in this situation: Rafters with insulation Woodfiber. Membrane (taped at joints) Battens Counter battens Tiles. 1
